Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
My steam cleaner want suck the water up
I need advice on how to get my cleanner to suck up the water
  • 1,673 Answers
Re: My steam cleaner want suck the water up
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter. Also make sure that the lid is on correctly and not loose one end.
Posted on Jan 10, 2008
0 characters
3 Points
Is it possible to vacume water with the miele slaris turbo plus?
I wouldn\'t attempt that unless it says you can do that in the manual. Use a steam cleaner. They are made to suck up water.
May 18, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Steam coming out of Miele S7000 upright vacuum cleaner
There is no steam generator on your Miele. It can only be smoke or dust. Are you certain it is steam. If you have sucked up water the motor could be in danger of shorting out.
Aug 12, 2013 | Miele Vacuums
Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
May 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissel proheat carpet cleaner is not sucking up the water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Oct 08, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 1699 ProHeat Clearview Steam Cleaner won't pick up
Usually if the water isn't being sucked up is either the filter in the lid of the tank is clogged, or the gasket that sits on top of the clear window nozzle and the tank is missing.
Jan 08, 2008 | Bissell 1699 ProHeat Clear View Upright...
Eureka deep steam cleaner
When these stop picking up water, I assume it is spraying the water out, is because of a missing seal, where the suction port is, or a filter is clogged. Tank isn't set down like it should be.
Jan 02, 2008 | Vacuums
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
108 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
