I formatted my laptop..
since i lost the CD driver, so i download all of them..
but i cant have the audio driver that fixed with my laptop..
my laptop HP Pavilion dv1000. And my other prob is that my notebook gets shutoff within 15 minutes.Its 2 years old.I had repaired it once at $110 and now after 6 months its the same prob again, so please tell me a solution about my problems?
I have the same problem here.. i re-install windows, home premium to Xp pro sp2, and my note book model is Hp dv1000, i downloaded driver from hp site but it does't help... i can't even connect to internet.. i think i need the whole driver.. sounds did't work, and even the quick play bottom... can any one help me. thank you
I need help to install audio driver for the hp pavilion dv1000 if u can help me with this problem i will realy appreciate it thank you and will be waiting your response.
Please help me i have got the same problem. Formated my laptop, lost my CD and am now worried about sound driver.
Hp pavilion dv1000 audio driver.
Download d audio driver frm hp website
This problem is peculiar. First concerning the sound, the audio driver on hp site doesnt work, u need to download the universal audio architecture (UAA) driver ( try this site: http://driverscollection.com/?H=Pavilion%20dv1000&By=HP). This is the driver u need before the sound will work.
Secondly when my laptop began to shut down on its own, i discovered it was a fan problem. The processor fan would seize causing the processor to over heat and consequently causing the system to shut down. Fortunately I repair pcs so i was able to bring out the fan, work on it and my system is behaving fine now. Alternatively you could take it to a repair shop and have the processor fan replaced, that will the the darn thing to stop shutting down after some minutes.
Goto the hp site http://www.hp.com there you will find all the drivers you require.there are more than one lot of drivers for audio so download them all ,one of them is right for you,the same with other drivers.if theres more than one driver and youre not sure which one you need ; download them all.
problem with pc turning off ....right click in desktop and select properties and check power settings in screensaver properties...there youll find config for hibernation,lid switch,sleep mode etc....
While installing sound drivers on your HP laptops the first and the most important thing that you will have to consider is its compatibility.
A sound driver that you choose needs to be compatible with your PCs
Operating System and the sound card installed on your HP Laptop.
Then, in case if you fail to choose the right driver, the installation will fail and you will not get the expected quality.
Thus, while downloading drivers from the website try to download the drivers that are compatible with your systems sound card.
Get more information to fix HP Laptop sound drivers problems :
http://supportforhp.iyogi.com/laptop-sound-drivers.html
http://www.tomshardware.com/forum/242957-44-ze4900-laptop-sound
Hope this helps you.
I have the same problem when my friends ask for my help re installing his pavilion dv1000 because a HD crash.
After installing windows in the first partition, leaving behind about 40 gb of the HD, i started to install the quickplay app.
1. I leave the 40 gb unchange, unformat - it didn't work
2. I create 204 mb of primary partition - it didn't work
3. I create 212 mb of EXTENDED PARTITION - unformat and leave the rest ( 40 gn - 212 Mb ).
Try to install the quickplay ...and it works..
The quick plqy app. formatted 204 MB next to my 212 extended partition.
Because i'm too lazy to try another shot, i leave the 212 extended partition, 204 of quickplay formatted partition unchange - and used the next sector to create partition for data.
Hope this information can help.
Check tis site :
http://h10025.www1.hp.com/ewfrf/wc/siteH...
Check the bottom of the notebook, some dv1000 models were CTO and had for some reason a second model number, in my case it was http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3191023#
for this model there was a second download for a microsoft UMM bus driver that needed to be installed, after that the problem was fixed
SOURCE: HP Pavilion dv1000
the graphics chip is an Intel(R) Graphics Media Accelerator 900 ,go and get it here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-22940-1&cc=au&lc=en&dlc=en&product=500515&dlc=en&lang=en
go into windows control panel and select power options, it may be set to shut off after 15 minutes ,set it higher,if you use the power lead plugged in, set that setting to never sleep,shut off,etc
good luck
Terry
i formatted my laptop .. i successfully loaded all drivers except audio drivers ..
pls solve my prob..
thanks
SOURCE: i formatted my laptop.. since i lost the CD
Hi below are the download links :
www.hp.com/cposupport/eschome.html
www.opendrivers.com/.../notebook-hp-free-driver-download.html
Regards, Jaya G
the audio is not working on my computer, the driver is not working after i re-intalled windows.
my name is Anthony and my e-mail adress to reply is:
[email protected].
Thankyou.
Removed Home edition and Installed win 2003. But audio and sound not working
audio driver in win2k03
SASXA
asaefdsgfdsfdafsafSF
I had formatted my laptop and lost my driver cd.I have downloaded all the drivers from the website but the audio driver is not working.I try to instal it and it shows failure.
i format my pc and i am looking for the drivers that i need for my pc.
i am using windows vista but dont have sound on my computer, i have tried to install sound online it is not accepting
My laptop is Hp dv 1000, I discovered that the system have a virus on it and I format it all and reload it back with Window Xp Home Edition but since then the sound is not working. I have try many Sound Driver that I download on it but it all the same, It used to give error after Installation.
how ca i get a driver for my audio?
no audio output device is installed
can not get the audio driver
yes
i need to download audio and graphics drivers
Når jeg formaterte min pc, mistet jeg lyg og prøver jeg å få den den til bake
thers no sound
i have same problem
I also have a same issue with my laptop hp pavilion, I already tried installed any driver but it was still no happen. Please help me with this and I carrying this since last week.
when i talk through skype other party cannot hear, I tried to record my voice and it is not getting recorded
