Question about Jabra FreeSpeak BT200 Consumer Headset
No accept password 0000 (Jabra BT200)
Jabra BT200
Phone no accept password '0000'. Answer is 'bad password'. What can I do?
  • Anonymous Mar 11, 2009
    cannot connect to phone 0000 password
4 Suggested Answers
SOURCE: HTC Mogul does not accept
try 00000 (five zero's) or 1234 or 12345; the first should work the others will work as well
Posted on Feb 18, 2009
gzuckier
  • 3 Answers
SOURCE: Jabra bt200 passcode
you mean the one you type in to get recognized? i don't know this model precisely, but all the jabras I've seen take 0000, four zeros.
Posted on Apr 23, 2009
BoraDURSUN
  • 47 Answers
SOURCE: upgraded my phone software cannot connect my jabra
Check that both devices are in pairing mode and the phone lets the headset connect without asking for authorization.
There might also be a security / firewall issue. You might want to check your phone settings...
Posted on Jan 07, 2010
Where do I get the passkey to pair with my phone.
the passkey is 0000 you can find all of the quick start information at this link:
http://www.jabra.com/sites/mobile/ap-en/products/pages/jabraeasygo.aspx
thank you,
Lee
Sep 20, 2011 | Jabra EasyGo Bluetooth Headset
My jabra blue tooth asking for pass code , i tried with 0000 and 1111 and 1234 and 9999 but no use please help me
1. Put the headset in pairing mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT130
Follow your phone's instruction guide. This usually involves going to a 'setup,'
'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover'
or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT130
Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on
the phone and confirm with the passkey or PIN3 = 0000 (4 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
Jun 21, 2011 | Jabra BT130 Wireless Headset
I do not have my manual to sync my bt350 with my new phone how do I do this?
Before you use your Jabra BT350, you need to pair it with your mobile
phone.
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 5)
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’
or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4
zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
hope this helps
Jan 30, 2010 | Jabra BT350 Bluetooth Headset Headset
I need instructions to pairing the Jabra BT2020 bluetooth to a PS3 system. I've misplaced the directions to the headset unit.
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
password is 0000
Jan 02, 2010 | Jabra BT2020 Bluetooth Headset
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
• Make sure the headset is off .
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
Apr 23, 2009 | British Telecom Jabra BT200/BT250/BT250V...
Jabra vbt185z, light stays on, won't connect to phone
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
Dec 29, 2007 | Nokia 1600 Cellular Phone
Connecting to a jabra hands free
once you have found it it should then ask for a pin code which is either 1234 or 0000
once this is accepted then they should be paired completely
Nov 25, 2007 | Cell Phones
I couldn't get it to pair this morning
From the manual )link below),,,, 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press and hold the answer/end button until a solid blue light comes on. 2. Set your Bluetooth phone to ?discover? the Jabra BT350 Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* (See example from a typical mobile phone in fig. 5) 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Jul 28, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra FreeSpeak BT200 Consumer Headset Logo
353 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
