Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven Our GE Spectra XL44 oven does not maintain its temperature
  • 13 more comments
  • Anonymous Jan 01, 2008
    tried to cook a 6 lb prime rib roast - 4 hours later at temps ranging 350-400 it was raw and cold in the center
  • Anonymous Jan 02, 2008
    no problem with the top burners - but the oven does not maintain temperatures between 325 and 400. Even at 400 it will just turn off.
    oven sometimes gets to temp sometimes no broiler works fine
  • Bruce Gray Feb 25, 2008
    We have a GE Spectra XL44 and problem seems to be when we preheated the oven to 350 degrees (if it ever gets there, it beeps let you know it's preheated, right). Well, go to find out it's not at 350 degrees, it's at 275 degrees. What's going on with theses ovens????????? A neighbor told me to unplug it for 3 hours and plug it back in ( a computer error or something). I would like to know the PROBLEM SO I CAN COOK!!!!!!!!!!!
  • Anonymous Apr 17, 2008
    have a XL44 and the thermocoupler will not maintain set point temperture. I think the thermocoupler is bad. need a replacement.
  • Anonymous Apr 18, 2008
    We also have a GE XL44 that does not maintain its temperature range and the gas seems to be leaking... the smell is awful!
  • sailshark May 26, 2008
    Same problem, oven takes half an hour to heat up to 350 and doesnt keep the heat . what do i do???
  • Eric_mask Sep 25, 2008
    I have the same problem and in order to maintain the temp I have to use one of the burners.
  • murphdesign Sep 29, 2008
    We are experiencing the same problem. Our range is 6 years old and the oven has never worked right. We have had the ignitor replaced about a year ago. It worked ok for a while then it would not heat up beyond 100 deg. When it does come up to temp it shuts down and you have to reset. We are ready to junk it and buy another brand. Any information would be greatly appreciated.
    Thanks -
  • Puppyzeus Nov 25, 2008
    My over in about 4 years old. I set oven to 350 it beeps ready, it's not though it's about 275-300. This darn thing will not maintain heat either. It's at 400 but is cooking at 300. Not good for chicken. I don't see any answers here. Are there?
  • rooman Dec 26, 2008
    We have the same issue. Set pre-heat to desired Temperature. Beeps and indicates it is at temperature but is really only sustaining a much lower temp.
  • sergenangie Jan 11, 2009
    Same thing here! Although I have noticed that if I switched from the regular oven setting to the convection setting the oven heats up to the correct temperature setting. I've contacted GE and am waiting to see what they are going to do about this problem....I'll let you know if I get a good answer....in the meantime, it would probably be helpful if everyone having this problem would also contact GE and demand they stand behind their product!
  • Anonymous Mar 16, 2014
    How to install oven ignitor on jgbp40 GE spectra xl44
  • Anonymous Mar 24, 2014
    can not adjust temperatures, touchpad will not adjust
  • Anonymous Mar 30, 2014
    oven lock
Same here, my wife freaked cause Christmas turkey took 6hrs.
I read somewhere that its internal thermostat. GE should offer to look into this seemingly wide spread problem
Posted on Jan 01, 2008
2 Suggested Answers
WhIzAtIt
  • 136 Answers
SOURCE: GE Spectra XL Oven does not maintain oven temperature
The most logical solution for your problem would be a faulty thermostat, but yet at the same time i dont understand how it would heat to the temp desired then not come on at all. I would definately change the thermostat to start off with. Let us know :-D
Posted on Sep 14, 2007
Xl44 spectra oven temp very low
Fixya does not sell parts and cannot recommend sources.
Jul 18, 2017 | GE Spectra JGBP35 Gas Kitchen Range
I have a GE xl44 Gas stove. Oven will light, but not maintain temp. Broiler works fine. Ideas?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Xl44 does not reach or maintain setpoint . Display indicates increases of 5 degrees/second, but temp is not reached or maintained.
Have your oven ignitor checked. If they do not get hot enough quick enough the oven will light intermit. Usually when it does light you will often get a scent of gas or a poof. If that's the case, change the ignitor
Sep 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
I have a ge profile xl44 oven and do have the
I just converted aXL 44 from natural gas to propane and I don't have a manual for it do I need to do anything for the oven part?
Also how do I light the pilot light or do I need to?
Greg
Jun 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
910 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
