Question about Paradyne 6200 ADSL2+ Router
Hookin a laptop and desktop to DSL internet
I have a desk top and a lap top computer can i hook them both to the DSL internet with a paradyne 6200-A3-200 router.
5 Suggested Answers
SOURCE: 6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
Admin/Admin default id and password
Posted on Mar 06, 2008
SOURCE: what is the username and password for paradyne adsl2+ 6211-A3-304
The default username is Admin and the password is Admin. Both are case sensitive
Posted on Sep 04, 2009
  • 85 Answers
SOURCE: what is the ip address of paradyne 6381 a3 300
To configure your router, open your web browser. Type the default IP address ( into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is
The default user name is Admin
The default password is Admin
Both are case-sensitive.
Posted on Jan 08, 2010
  • 10406 Answers
SOURCE: network extender
You don't -- the strength of the transmitter inside the unit is what limits the signal-strength out at 300 meters.
Instead, you need a "repeater" -- some people have built their own, using a Linksys router, and then reprogramming it with the free 'DD-WRT' software, and configuring the device as a repeater, rather than as an Access Point.
Posted on Aug 23, 2010
  • 11800 Answers
SOURCE: The combined Paradyne router and
You buy a new one, you install it in the place of the other and you configure it following the manual - you will need the connection data from your ISP (username and password - they are in the contract).
If you no longer have it you can download it from here
Posted on Feb 16, 2011
0 characters
1 Points
I can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these...
you should type in
In your request you have:
i can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these componets are hardwired to cannot.has worked fine for years but stopped suddenly!!!!!!!!!!!
Nov 11, 2010 | D-Link AirPlus DI-524 Wireless Router
My WRT54GC router suddenly stop passing internet through it after 4 years of uninteruped service. But all the LED s are on as they should be. I can not get either wired (my desk top) or wireless (lap top)...
Has your modem been hard reset recently? if so, it may require that you bridge the modem out to work with the router- ESP. if you use Verizon DSL. If so, contact your ISP, and ask for assistance in bridging out the modem.
Oct 03, 2010 | Linksys WRT54GC Compact Wireless-G...
When I hook up my Dell2350 router to my westell dsl modem i can not access internet with my desk top or my laptop. When i disconnect the router I can access internet through dsl for desktop with no...
You will need to check the settings of the router. You are able to go online when you connect the computer directly to the modem. Your internet service provider is DSL. You can try to reconfigure the router. Press the reset button on the router for 30 seconds. release it. unplug the power to the router. plug it back in. wait for 1 minute and try to reconfigure the router. Click Here for step by step set up
Nov 18, 2009 | Routers
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
Oct 27, 2009 | Routers
This is my situation; I have a hard wire connection from my wall phone/DSL outlet to a Westell model C90 DSL router/modem. Since this allows for only one single hard wire connection to one desk top (I have...
So you are connecting the DSL Modem output to the D-Link's LAN port 1, right? In this case, you should connect the DSL Modem output to the D-Link's WAN Port, which is between the power input and the LAN outputs.
If it doesn't work that way, check this out:
Aug 24, 2009 | Routers
Basically if your Internet service is DSL or cable it's just a plug and play. Just plug the computer to the modem once the Internet access has been activated by your ISP and your computer should automatically get connection from the modem.
Aug 16, 2009 | Paradyne (6211-A2-200) Router
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Constant disconnect on both laptop and desk top
  • If you bypass the router and connects your computer directly to the your DSL modem, do you have a stable Internet connection in your computer?
  • If you do, you may reset and reconfigure your Belkin router.
  • You may also do a firmware upgrade on your router.
Hope this helps!
Nov 23, 2008 | Belkin Routers
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
Belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Jan 05, 2008 | Routers
Paradyne 6200 ADSL2+ Router Logo
15 people viewed this question
Top Paradyne Routers Experts
 C. Dante
C. Dante
Are you a Paradyne Router Expert? Answer questions, earn points and help others
