Question about Western Digital (WD1500ADFD) 150 GB Hard Drive
Installing windows xp with 2 new sata wd 150g 10k 16m raptors to NO avail...
I recently bought 2 new sata 150g raptors with secure connect 7pin, 4g of patriot viper 240 pin ddr2 sdram, ddr2 800mhz pc2 6400. My mobo is a ecs k8m890m-m.
When I recieved the hd's, they did not come with jumpers or software. So I did not think of it. I installed both and my ram & started fresh with xp install. That is where my probs started. I have looked everywhere on the net to find a good jumper setting illustration, but I cannot find. My installation will not complete and my pc keeps looping and not installing completely. Please help
  • 90 Answers
I guess you are trying to install Windows XP in RAID 0 configuration. If so, you need to do several steps:
1. Configure the bios to work as RAID 0
2. Download the RAID driver from the mobo vendor site, copy it onto a floppy disk and have it ready for when Windows asks for it.
See this link for detailed example http://www.duxcw.com/digest/Howto/mb/abit/kx7-333/raid1.htm
In SATA there is no master/slave configuration, so there is no need for jumpers.
I hope this answers your question.
Posted on Dec 28, 2007
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
Can't install WINDOWS.
Install the XP Pro first, install the necessary drivers etc. Then after that load the other disk for windows XP Home install it choose the drive to install the OS, install the necessary drivers etc. you will see two operating system while going to boot section of the computer.
Mar 11, 2009 | Dell Dimension 8400 PC Desktop
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Raptor X seen on BIOS, but not on bootup
To speak Microsoft Window Customer Support representative dial +1 (800) 204-4427 (U.S.) 6 Am to 6 Am, (24*7 hours) Pacific Time, Monday through Sunday. If you needs a technical diagnosis you can call on our Microsoft technical support team 1-800- 204-4427, which is especially open round-the-clock for online assistance.
Our highly trained and experienced technicians have deep knowledge in fixing different types of all type Windows technical problems and have extremely high success rate in troubleshooting. To use our reliable Vista tech support services, please call our toll-free Tech Support Number at +1-800-204-4427.
Apr 26, 2017 | Western Digital Raptor X (WD1500AHFD) 150...
Hdd wd raptor 74 gb serial ATA
does the machine recognize the hard drive ????
Windows software doesn't care what hard drive you have, as long as the machine can detect it and mounted.
Sep 06, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Trying to install windows xp on SATA hdd wd raptor 74 g , i can see it in bios  but can`t install windows on it, i boot the cd with data lifeguard tool from western digital but nothing....need help
you need to put the sata drivers onto a floppy disk and when it asks during the xp setup do you want to install any 3rd party drivers say yes and load the drivers from the floppy. The sata drivers with the floppy generator should be on the drivers cd you recieved.
Oct 25, 2007 | ASUS S-presso Standard S1-P112...
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
Western Digital (WD1500ADFD) 150 GB Hard Drive Logo
133 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
