If you have recently dropped the camera you may have damaged the camera tube (housing) or knocked the zoom mechanism off its track -- both are problems that require professional repair. Otherwise, your problem may be due to weak/worn out batteries or corrosion on the
battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the
batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, chances
are that your batteries need to be replaced because they're just too
worn to properly power the camera.
I just bought a FUJIFILM Finepix j38 less than a month ago. It has worked great up until now. I zoom...
(More)
I just bought a FUJIFILM Finepix j38 less than a month ago. It has worked great up until now. I zoom in and it reads "!Zoom Error"... Any ideas?? Please Help!
This morning I showed my family the pictures on my Fuji camera which I took in Bangkok and...
(More)
This morning I showed my family the pictures on my Fuji camera which I took in Bangkok and Tokyo.
Then I took a plane home from Los Angeles. I just came in (from a flight from LA to Dulles) and tried to show the rest of my family the pictures and what comes up in a wierd black and white outline on the screen. The camera traveled in my suitcase just like it did when I took it to Bangkok. It is fully charged. I hope I have not lost my pictures.
Hi, No damage, no water, no something unusual is happened to the camera (the new one: only 2 month)....
(More)
Hi, No damage, no water, no something unusual is happened to the camera (the new one: only 2 month). Just one morning I've got this error: "zoom error". Any idea,
my camera FUJIFILM FinePix A400 has a focus error. The zoom is locked. Does anyone explain how I fix...
(More)
my camera FUJIFILM FinePix A400 has a focus error. The zoom is locked. Does anyone explain how I fix it? Please answer to valee.martin@hotmail.com
