Question about Canon imageRUNNER 2010F All-In-One Printer
Canon 2010F How do you make double sided copies for this copier?
5 Suggested Answers
  • 62 Answers
SOURCE: Setting the copier to Double Siding as Default
Select the Double-side function that you require as standard. Select COMMON SETTINGS, found in Additional Functions (X) button. Select the Store Common Functions setting and press OK. Think this is correct, let me know? In order to reverse setting, follow instructions to get to STORE selection but select INITIALIZE. Hope this helps.
Posted on Mar 16, 2008
Copier_God
  • 57 Answers
SOURCE: HOW CAN I GET CANON 2010F MANUAL
Have a look on this site, you will find many canon manuals on here.
http://www.nodevice.com/search/results/canon+2010/in_man.html
Posted on Oct 16, 2009
PATHAMPAD
  • 25 Answers
SOURCE: Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Posted on Oct 31, 2009
canontech
  • 1219 Answers
SOURCE: DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
Posted on Jun 14, 2010
1 copy to front and back from computer
umm if I understand correctly you want one document printed same document on both sides select double side printing the where it ask for how many copies you want send to or how many of the documents you want in increments of two ex. 2=1 double side copy,4=2 double sided ,6=3double sided
May 21, 2014 | Kyocera CS-2550 Black and White Copier
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
I AM TRYING TO FIND HOW TO COPY FRONT AND BACK PAGES.
copy the front page and when it prints, put the copy in the paper holder backwards and copy the back page. This new copy will have the front page and back page on the same sheet of paper.
Oct 07, 2010 | Canon imageRUNNER 2010F Copier
We have 2 Canon ImageRunner 3320N copiers, but they are behaving differently when they are being used as a scanner. On one copier, when scanning a double sided paper it will automatically scan each side....
it is in the copier settings. one is actually set up to automaticly do doublesided copies as a default. while the other one is only set up to do singlesided copies
first while on the main copy screen change the setting how you want the copier setup ..... double sided printing, black and white, or how ever you want your defaults to be set up
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to the double sided copies.....
hopefully this will fix the problem if not get back to me
Jun 18, 2010 | Canon ImageRunner 3320N Copier
What do i need to do when my copier canon 2010f says E-100
You need to replace drum unit.For first aid you can try to remove drum unit and put it back.
Mar 10, 2010 | Canon imageRUNNER 2010F Copier
Canon imageRUNNER 2010F All-In-One Printer Logo
old marine
old marine
