Question about Kenmore 24 in. 16492 / 16494 / 16499 Built-in Dishwasher
Door falls open
The door on my Kenmore Elite 16492 dishwasher now falls open instead of the spring tension that used to be there. I feel that it may pose a danger to my 2 year old daughter if she happens to hang on the door, and it falls open freely instead of with the spring assist. Is this an easy fix? How do I get at the mechanism that controls the door? Thanks!!!
  • BoulderScott Dec 28, 2007
    I have the same problem! I took of the face plate at the bottom (below the door), but saw that the dishwasher is pretty tightly wedged under the counter top. I don't think you can access the spring from the front and I was worried I'd break a hose or fitting pulling it out myself. I have the Sears repair guys coming out tomorrow. I'll let you know what they say...I'm afraid I'm going to break my leg when that door slams down!
    Scott in Boulder, CO
  • lindalysaght Dec 31, 2008
    I know this is an old posting but we have already repaired it once this way. NOW, the white plastic things you thread the cord around seem to have come loose on one side and we can't decide how best to fix it. Anyone out there with the same issue. I, too, paid almost $1K for my dischwasher and this is a pain in the A--.
I have had this issue TWICE now on a three year old dishwasher, and Sears charges you $150.+ to fix it. It is quite simple to fix, there is a special part that has all the pieces attached to it, except for the spring. You will have to remove the screws that are holding your dishwasher under the counter. This could be behind the rubber on the sides. I had to remove a gray plastic circle piece on the inside to see the screw (it pops right out, don't loose it!). Pull out the machine enough to see the out side- side. You will see a (plastic) white roller, string(rope), and a piece that attaches to the dishwasher. There is a number on the white plastic piece that looks like a L (it just slides out). Thess pieces are called the Dishwasher Door Balance Link. You will need to order these pieces, they are all inclusive, and come for both sides of the door, at a whopping price of $15.00. VERY simple to install. Attach one end to the spring, line up in roller then attach to the dishwasher. It is easier to look at it and follow what is on the dishwasher than me clearly explaining it. I feel that paying $1000.00 dollars for a dishwasher would warrant using metal pieces instead of substandard plastic, for this application. These door are very Heavy and like I have said I have replaced them twice with a waiting time of three weeks for the repair man. Please try it, you can do it.
Posted on Dec 31, 2007
FYI I doubt you need to buy the springs - when the plastic or cord breaks and loses tension, the spring is still sitting there. Its a heavy metal spring and isn't likely to "break" You can save a few bucks by not buying new springs.
Also you can often just reach under and do this without pulling the machine out, which is much faster although a little more challenging. But that way you dont need to disconnect the waterline, etc.
Posted on Aug 26, 2008
Jeff and Badadrtr,
Thank you for the advice and help (including part #'s!) to get this fixed. I ordered the parts from Sears on-line and paid about $15 for the spring, and about $13 for the plastic cord and roller. Plus tax and shipping brought my total to about $40. I couldn't find these pieces on ebay, but I may not have searched correctly.
Only difficulty was pulling the dishwasher out from under the cabinet. Loosened the leveling feet and pulled...what was holding it was the water line in from the crawl space. Went below and shut the water off, disconnected and it came out far enough to attach the spring and new cord.
Took about 1.5 hours with the complications, but very easy when I got the washer out! THANKS!
BoulderScott
Posted on Jan 14, 2008
Thanks for all the help. I actually pulled my dishwasher out, and it is a very simple fix just like you said. I can't believe that it is only a simple cord with some plastic pieces on the ends. What a cheap way to go on that.
For BoulderScott: I actually found the parts on E-Bay of all places!! The part number for the spring is 8270182, and the part number for the cord and roller set (2 of each in the set) is 8194001. Very easy once you pull the unit out. Make sure you turn the leveling feet in before trying to pull it out. Those should be accessible by removing that bottom panel. Hope this helps for anyone else also.
Jeff
How do I adjust the door tension on a Bosch SHU 6802 undercounter dishwasher to keep it from falling open
you cant change the tension more likely one of the ropes attached to door spring has snapped so you are only getting counterbalance from one spring not two.
Feb 04, 2017 | Bosch Dishwashers
Frigidaire Dishwasher Door Repair
http://www.frigidairepartscenter.com/
1-800-935-0062
have your model number when you call and this parts center will be able to tell you what parts you need and you can order the parts through them. If you need more help, let me know...
Mar 20, 2008 | Kenmore 24 in. 16492 / 16494 / 16499...
How do I repair the spring that holds dishwasher door?
The door spring can be seen on the side of the frame just below the bottom of the door. If the spring has just popped off you can put it back easily when the door is open. If the spring has become weak, you can get a new one from an appliance parts store or online.
Jun 10, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Jul 31, 2014 | Kenmore Dishwashers
Kenmore elite dishwasher model 665.16493300 door falls to floor when opening
Door springs are located at the left and right side of the door bottom. You will have to pull the unit a few inches from the installed location to see them. If broken, replace. If one slipped off, reattach.
Mar 09, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
I have an ASKO D3251. Door free falls when opened. No longer has tension to control downward movement.
Your springs are faulty.you have two of them and will need to pull the unit out and inspect.usually on asko dishwasher you have to order the whole tension spring assembly .
Jul 29, 2012 | Asko 24 in. D3250 Built-in Dishwasher
Kenmore dishwasher elite door opens too fast, broken spring?
Could be that, the spring may have unhooked or it could be a defective damper connected to the door. Remove the side panels and check the operation of the door mechanism. (This will probably require the removal of the rear panel to gain access to the necessary fastners).
Jan 21, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Apparently the springs on my door are either not connected or they need to be adjusted. If I were to open the door and not hold it with my hands, it would immedaitely fall wide open. No tension exists on...
I had the same problem on my Dishwasher . There should be 2 screws underneath the top front part of the dishwasher. They hold the unit in place. Easy to get to. Open the door and look up. Pull out the 2 screws that are screwed into the underneath of the front cabinet.
This should allow you to pull (slide) out the unit just enough to see the springs ( aprox 1 ft ) on both sides on the bottom of unit. Inspect the springs. Mine had broke on one side where it clips into the holder.
I just inserted the spring in the proper tension hole to match the other side . I spun it around 1 turn as to hold it in place and then connected the top of spring it its proper place. This gave equal tension on both springs and the door works fine now.
Eventually I will buy a new spring and replace it but at least it works fine for now.
If even one spring has been disconnected the door will fall with out any tension what so ever. I'm guessing maybe just one spring has either come out or broke where it clips into the hole.
Aug 30, 2010 | Frigidaire FDB520RHS Full Console...
Door spring broken
the door links are broken need to get new ones and replace
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 16492 / 16494 / 16499 Built-in Dishwasher Logo
1,966 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
