Hampton Bay 24002 Ceiling Fan
Problem for Hampton Bay 24002 Ceiling Fan
I bought a home with a HB ceiling fan with a short
By billschoettl on Oct 12, 2009
I bought a home with a Hampton Bay ceiling fan with a short down rod. Can I remove the rod so the fan is higher to the ceiling. I need to add a light.
Solution #1
posted on Oct 12, 2009
Not Rated)
avid101
Rank: Guru
Rating: 88%, 1285 votes
sure you can raise it higher and you can shorten the rod or make it longer the rod has nothing to d o with balance.
Was this helpful?
Yes
No
Solution #2
Not Rated)
StarGGundam2
Rank: Master
Rating: 90%, 18 votes
Unless you are able to find a shorter rod this is not possible. Especially since the rod is needed to keep the ceiling fan from rocking and tearing down your ceiling, It has to be able to move freely to function properly.
Please rate my answer. Thank you very much.
Was this helpful?
Yes
No
Solution #3
Not Rated)
tstewart1956
Rank: Guru
Rating: 85%, 175 votes
YES YOU CAN REMOVE THE LONGER ROD AND JUST MOVE THE FAN UP
Was this helpful?
Yes
No
Popular Solutions for Hampton Bay 24002 Ceiling Fan
Questions and Unsolved Problems for Hampton Bay 24002 Ceiling Fan
Do you recommend Hampton Bay 24002 Ceiling Fan?
Answer
Answer
fan works with remote but not the dimmer .settings are in sync with receiver.lights turn on but... (More)
Answer
The fan goes at top speed. I have changed the batteries and set the temperature above the indicated... (More)
Answer
Remote works fine but the fan does not. No light and no movement. I have misplaced manual to the fan... (More)
Answer
I have a ceiling fan with 3 Speed Pull Chain and need to connect the capacitor with 3 wires and the... (More)
Answer
fan does not come on and spin blades. just a year old. light works
Describe your Electric Fans problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Electric Fan Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
