Acer Aspire 4520-5582 PC Notebook
Problem for Acer Aspire 4520-5582 PC Notebook
Atheros wi-fi on Aspire 4520 not working
By govindra on Oct 12, 2009
hi all, a-slaam!
i got this laptop from a friend and foolishly decided to format it and start clean over again. i slipstreamed xP Pro x86 with SP3 and all latest drivers using nlite and got a clean, fast, wonderful load.
but wi-fi began giving problems.
on occasion it turns on. then works almost each time i reboot.i once left the laptop to go into suspend and the wi-fi stopped working. pressing the wireless button showed "no device"! various re-booots later, it continued to fail to detect the wireless card.
then i did another install using slightly different config and set "wireless zero config" to be started manually (thinking it might be the culprit).
it kind of worked as on next boot as it recognized the card. i started the WZC service to search and connect to my home wireless gateway. slipstreaming helped in not loading windows generic wi-fi drivers and only Atheros was loaded.
but sadly, it stopped working again.
however, when wi-fi does work, it works wonderfully! no problem with range or speed! terminal services and UDP and TCP work beautifully. all else like flashing orange light etc works absolutely fine each time the wireless card is discovered.
but when it fails, it is very disappointing!
thinking that the card maybe damaged, i tried the AR5BXB63 card on another machine and works fine! some one told me that the PC bus may be the culprit. and as i said, before the i took the decision to format it, it worked flawlessly.
i have the ACER-OEM original XP2OEM_EN CD which i used to slipstream. thinking slipstreaming was the issue, i tried another clean install (with all windows drivers and SP2), then upgraded to SP3 and the latest drivers, but the problem persists.
pl advice! i'm so frustrated with the machine that i now plan to use it as a desktop only! this is my first and only laptop! pl help me regain its mobility!
thank you again.
regards, govindra.
Comments:
Oct 13, 2009
- @ burim09: thank you and i'm going to try and let you know. another thing i'm trying is to use Atheros Utility to manage the card and remove windows management completely. i'll try these drivers first though. regards, govindra.
Oct 13, 2009
- @ burim09: hi! sorry but none of the drivers worked! now the PCI bus is not even recognizing the adapter (same old problem). i forced installed as well using "Add Hardware -> New Device > Have Disk" and pointed to the .inf files of the drivers that you suggested i try. but card still not detected and there's a yellow exclamation mark preceding the Device list in Device Manager. how can i force it to detect? any way to know devices connected on the PCI bus that windows for some reason is ignoring? regards, govindra.
Solution #1
posted on Oct 12, 2009
Somewhat Helpful)
burim09
Rank: Wiz
Rating: 83%, 76 votes
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 4520-5582 PC
Questions and Unsolved Problems for Acer Aspire 4520-5582 PC
Do you recommend Acer Aspire 4520-5582 PC Notebook?
Answer
Answer
Installed software for a digital picture frame and now the SD card reader doesn't read y cards... (More)
Answer
first format your laptop and install inf from cd and install MICROSOFT UAA HDA this software then... (More)
Answer
acer aspire 4520 no se apaga, se reinicia
Answer
I have a T42 IBM laptop, and its screen turns black whenever I remove the charger. Why?
Answer
how large of a hard drive will the acer aspire 4520 mother board acept
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
