Question about Kenmore 16322
Bruner will not heat past 140 degrees, just bought a new tank
I just bought a new tank for my grill which has worked great until this tank. I have only had the grill for about 2 yrs. I have tried to re-seat the tank and still have had no luck on getting the grill back to it's origianl working condition.
Pls help!!
I just got done having the same problem. Disconnect the tank. Let the hose hang there for 5 or more minutes to drain any gas. Reattach the hose to the tank. Turn the knob on top of the tank SLOWLY 1/4 of a turn. Light the first burner on the left. Turn the knob on top of the tank another 1/4 turn. Light the rest of the burners from left to right. Don't open the tank valve any more than 1/2 turn altogether. When you changed tanks and hooked up the hose, the regulator in the hose cut back on the flow when the new blast of gas came through. (Its a safety feature.) So draining out the gas from the hose to reset the regulator and turning on the gas SLOWLY should give you good pressure.
Posted on Dec 22, 2008
We have a Weber Genesis Grill Silver and now we thought we needed gas and got a new tank. Okay now it will not heat up past 250 degrees. We found out about the trick with turning on the gas and...
Well, if turning OFF the tank valve, disconnecting the hose and wait 5 minutes before reconnecting it. And then, opening the tank valve VERY, VERY, SLOWLY (Slow motion slow) before lighting the burner farthest from the tank first and turning it to high didn't work. You need to replace the grill's hose/regulator assembly.
You can purchase one at any home center or hardware store that sells gas grills and accessories. They run around $30.00. Be sure to take your old one with you for comparison purposes.
Hope this helped you and Happy Grilling!!
Jun 06, 2011 | Weber Genesis Silver B Grill
Replaced both elements and tstats now there is 240 at both elements at once and only the top one is heating the bottom is coldreplaced bottom sgain thinking maybe bad from factory but still cold will i...
Electric water heaters never power BOTH the upper and lower elements at the same time.
If the water in the tank is cold, either the top OR bottom element will be powered through the upper thermostat (t-stat), never both at the same time. The upper t-stat will send power to the upper element until the temperature of the water in the top of the tank reaches the set point of the t-stat say 140 degrees. When the water temperature in the top of the tank reaches 140 degrees, the t-stat is "satisfied" and disconnects the power from the top element and sends it to the lower t-stat.
IF the temperature of the water in the lower half of the tank is lower than the set point of the lower t-stat, the t-stat closes to send power to the lower element. The lower element REMAINS powered by the t-stat until EITHER the water in the lower part of the tank reaches the set point temperature of the lower t-stat again, say 140 degrees; OR the temperature of the water in the upper part of the tank drops, at which point the upper t-stat "calls" and switches the power away from the lower t-stat and sends it to the upper heating element instead. When the top t-stat is satisfied, it switches power back to the lower t-stat. The process will continue back and forth for as long as needed to bring the temperature of the water in both halves of the tank to 140 degrees.
You must wait until the top of the tank is heated - before the lower element will be powered to heat the water.
I hope this helps you understand how the switching happens in these water heaters. Good luck! Please rate my reply. Thank you.
Mar 24, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Back Burner sometimes goes out when close grill -relights wn open
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Apr 06, 2010 | Weber Genesis Silver B Grill
My q grill is not heating properly. I have a full tank of propane and the grill is clean but the burner is not getting enough gas to heat past 200 degrees
Mar 30, 2010 | Weber Q Grill
Weber grill wont heat past 350 degrees. Tank is full. Not leaking gas.
either your regulator is not hooked up to the tank all the way try to turn tank off make sure all knobs are turned off disconnect tank then reconnect turn tank on and try again if this doesnt work the regulator is bad
Aug 09, 2009 | Weber Genesis Silver C Grill
Heating
It sounds like the regulator is shutting down and preventing the grill from getting all of the propane it needs. to remedy your problem disconnect the tank and then reconnect it. Usually that is all it takes to get the regulator to work properly. If the problem continues just get a new hose with regulator attached.
Jul 07, 2009 | Weber Spirit? E-310 Propane Grill
Weber won't get very hot
Safety valve needs reset.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait several seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and the rep walked me through the reset. All grills made after 1996 have this bypass valve.
Jun 21, 2009 | Weber Genesis E-310 Gas Grill
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Mar 23, 2009 | Weber Genesis Silver C Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Weber BBQ does not get hotter than 300 degrees
Might be easy! diconnect hose from tank ..and re-connect... this has worked for me in the past
Mar 15, 2009 | Weber Genesis Silver B Grill
Kenmore 16322 Logo
197 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
