Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
I tried to upgrade my firmware now it gives me the Rescue Mode Screen
Nothing works it just brings me back to the rescue mode screen. When I click reload OS it tells me to start the firmware upgrade but then the firmware upgrade says the player isn't plugged in. Please help
  • cvolatile Dec 28, 2007
    I used another computer to upgrade the firmware and now it works. Thanks for your help btw.
  • Tyuix Apr 02, 2009
    Same problem! Was working fine until I tried to istal firmware, now it's stuck in Rescue Mode. Tried a few things, including rolling back to WMP 10, which hasn't worked so far. Will try on a completely new computer which has not had WMP 11 or any creative software installed ever, as that is another solution but i'm not holding out much hope. Bought it second hand so am beginning to think it was £80 wasted! Annoys me that it was working fine before the firmware!
I had the same problem while upgrating the firmware. I asked CREATIVE and they told me to reinstall the Windows Medial Player 11. I upgrated the firmware again and now it runs.
Posted on Dec 28, 2007
Dell Digital Jukebox
Anything unusual happen to the player before the problem started? Dropped it or perhaps unplugged it from pc while synchronising? The most likely fixable problem is a loose connector on the HDD/main board cable, or a failing battery/power adaptor giving the HDD a voltage too low. unfortunately however the HDD on these players is a bit vulnerable to rough treatment. When you connect it to a computer, does it still appear as normal or is it not recognised etc. What operating system PC are you using - perhaps formatting from the PC first before trying to install the firmware will help. Are you using the latest firmware from Dell or are you using a cd that came with the player? Is your player still under warranty or do you want to try and open it up and have a check yourself. Let me know more info and what you wish to try :)
Aug 17, 2007 | Dell DJ MP3 Player
I have a vaio laptop when I turn it on I have a
You can recover your VAIO computer from the recovery area on the built-in
storage device. This recovery method is faster than using Recovery Media.
See
1. Press the ASSIST button while your VAIO computer is off.
The VAIO Care (Rescue Mode) screen appears.
2. Select Start troubleshooting (recovery).
Follow the on-screen instructions until the Choose an option screen appears.
3. Select Troubleshoot and VAIO recovery solutions.
Follow the on-screen instructions until the VAIO Care (Rescue Mode): VAIO
recovery solutions screen appears.
4. Select Start recovery wizard.
5. Follow the on-screen instructions
To perform custom recovery, select Tools and Start advanced recovery wizard.
Oct 16, 2014 | Computers & Internet
IBM Thinkpad R60 - how to run in safe mode
When it is starting up at the Splash Screen(windows logo screen) hold the power button in to shut it off this should bring up the menu to open in safe mode. Might take a couple trys.
Jun 21, 2013 | IBM ThinkPad Computers & Internet
Firmware error
Try going into rescue mode by pressing the Play button while inserting the end of a thin object such as a straightened paper clip into the reset at the same time, then hold the Play button until your Dell Pocket DJ turns on.
Scroll to "clean up" and select. This just defragments your players hard drive, you won't lose any data.
If that doesn't fix it try replacing the firmware. Download the most current firmware from Dell's support website. Scroll to and select "reload firmware" in rescue mode. Connect to pc with usb cable and power on player. Double click the firmware file on your pc and let it do it's thing. This won't affect your saved data either.
If neither of those work you may need to reformat the players hard drive. This will wipe out anything you had on the player. Scroll to and select "format all" while in rescue mode. Select "yes" then just watch the progress bar. Good luck!
Feb 17, 2010 | Dell DJ MP3 Player
My apple iphone has a blank screen no apps ,, am not ble to reboot need help
You need to put it into rescue mode. Search Apple.com for iPhone Rescue mode.
Dec 14, 2009 | Apple iPhone 3G
Having big firmware problems
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved
Oct 10, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Dell DJ won't reload or reboot
I would first suggest reformatting the DJ from Rescue Mode, and then try reloading the firmware from here: http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R107735&SystemID=PDA_MP3_DJ_2&servicetag=&os=WW1&osl=en&deviceid=9420&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=31&fileid=139674 If neither of those work, it may be time to look into some repair options. John Dell Customer Advocate
Aug 06, 2007 | Dell DJ MP3 Player
Rescue mode v1.13
ok , so did this person who tried this first just try it out of frustration? This is so crazy but we tried 4 times before it worked. What the heck. Does anyone have any guesses as to why it worked.
Thank you thank you - you just saved me 300.00.
Sep 24, 2006 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
207 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
