Question about Linksys Wireless-G WRT54G Router
Xbox live/linksys router problem
Trid to connect to xbox live but it says no connection to wireless. I did buy the adapter necessary because wireless router is on main floor and xbox is on 2nd floor
  • 556 Answers
These documents with pictures should assist you to complete the process. If I were you I might try to understand the second document before using the first.
The generic connection and configuration document
This is a good description of possible router options.
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Posted on Dec 26, 2007
Cant connect Xbox 360 to this wireless router
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Linksys WRT160N Wireless Router
I'm trying too get connected to xbox live but it's
This mainly depends on your internet modem, I use linksys when I play xbox live. Also I use wireless adapter, sometimes an ethernet cable as well to plug straight from my xbox to my modem. Make sure your modem is connected to the internet, and that if your xbox has a signal, or properly connected to it.
Hope this helps a little. Good Luck!
Jan 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to connect to xbox live with linksys router
Just to confirm you are using a wireless connection to hook up to the router? do you have the router model number? Have you configured the correct wireless settings on the 360? Make sure that if you have a key that you have entered it correctly.
also you can use the xbox support site for reference, use the left side panel to look at wireless settings and other help.
Thank you,
Oct 21, 2009 | Microsoft Wireless Network Adapter Xbox...
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Connecting xbox 360 live
if you plug the computer into the usb port a box will come up and you register it as for the adapter get the one for the xbox plug it in and go to the dashboard then console setting then xbox live connection then test connection and if it doesnt work try the linksys one or the wired one.
Jul 12, 2009 | Microsoft Xbox 360 Console
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
Xbox Live Connection Interrupted
Ok, all you have to do when it comes to buying a wireless reciever is to buy the microsoft brand one made for xbox live. (100 dollars) Once you have this;
1. turn of the xbox 360 and plug in the adapter.
2.turn on the 360 and go to the network settings option
3. this should bring up a page offering a view of you ip address and ect., go to the bottom link (3rd), and select it.
4. this should give you the option to select your wireless network, then connect to it and test the xbox live connection.
5. Once you pass the test, continue to hit "b" until you are back at the very main menu and begin playing!
Mar 12, 2008 | Microsoft Xbox 360 Console
If you're looking for an option to connect the XBOX consoles to your wireless G network you'll need to purchage a wireless game adapter (simular to a wireless bridge) like this one for linksys for each console you wish to connect. You will have to connect the game adapter to your pc first to configure it on the network and then connect it to the XBOX. Xbox should detect the wireless adapter and you should be ready to go.
Feb 20, 2008 | Computers & Internet
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Linksys Wireless-G WRT54G Router Logo
104 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
