Question about RCA RP4010 Clock Radio
Door dont want to open
I have problem to open the door on top to insert and take off cd. It seem to be stuck, it open just a little bit.
Pierre
pturgeon@mediom.qc.ca
  • johnnnyo Aug 08, 2008
    Door opens a little bit. I can pull up the door though and it will come up and eject the CD if I pull on it. I need to fiddle with the player countless number of times until the CD finally starts playing. The CD won't start turning initially when I press play. When the CD reaches a track near the end of the CD I get clicking sounds.
  • Anonymous Apr 11, 2009
    doesnt open, dances up and down and it starts to freak out.
Jette-le, pis achetes-en un nouveau fait en chine
Posted on May 16, 2008
My laptop win8 has a CD jammed into it by inserting it not secure in the tray. The door would not open. I then inserted a paperclip into the pin hole which released the door. The CD was not there and I...
you can remove the disc drive they are made to be replaced once you slide it out is only a matter of 4 - 6 little screws ant the cover pops off remove the disc and reverse the procedure piece of cake. :)
Sep 30, 2013 | Computers & Internet
CD BROKE IN DRIVE - NOW DOOR WILL NOT OPEN
Seems like some of the particles from the broken CD have remained inside. For manually opening up the drive there is a small hole in which you can insert a straightened paper clip. The drive bay will budge a little and you can pull it out manually. Secondly maybe the belt driving the open/close system has gone weak. Try tapping ******* top of the drive right after pushing the eject button. After you have got it opened i suggest you remove the drive from the PC and do a detailed cleanup by completely dismantling the drive.
Jan 04, 2012 | Dell Inspiron 570 MT PC Desktop
Dvd tray stucked
take the top off the dvd player and see if something is stuck in the player. also a little bit of vasaline on the dvd door tracks helps for ease of movement
Nov 20, 2011 | Televison & Video
I have a Toshiba Satelliet P105-S6114 my dvd rom does not work is it very hard to replace
open cd rom door just clean lense with soft cloth ...if same
remove cd rom romove top cover then romove buttom u can see on back of lense two veriable for lense adjustment try one by one one adjustment is for normal cd and one is for dvd cd dont try together.. move little bit...and clsoe and then check... Thanks
Sep 05, 2010 | Toshiba Satellite p105-S6114 Notebook
WE CAN'T OPEN THE CD DRIVE ON OUR COMPUTER
I do not know the particulars of the eMac, but most CD drives have a little hole in which to insert a needle, in order to open the door manually, and extract the stuck CD. Look for it in the area surrounding the retracting door. Some units dont have doors, and inserting a pin will also force the disk right out.
Jun 14, 2010 | Computers & Internet
Driver side door lock won't open or lock using remote.
if it moves even a little bit when the button is pushed it wont be a fuse issue, you more than likely have a weak door lock actuator
Nov 25, 2009 | Cars & Trucks
Cd jammed in top drive
On almost every CD/DVD drive there is a small hole next to the eject button. Take a fine needle (be careful) and with a cork on the other end to save you from hurting yourself - push the needle into the hole until the cd drawer opens. Do this with the machine swithced off. Then remove the cd.
I hope this helps you.
Aug 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
C d door stuck
you can find a small hole at the front side of your cd drive , carefully insert any pin inside this hole and press it , your cd drive door will open.
Some time holding the cpu in 90 degree angle while system is on and pressing the eject button releases the cd door.
Feb 06, 2008 | Computers & Internet
ASUS 52CD-writer's door is stuck....
Is the door stuck shut? If so there should be on the front a little hole about the size of a pin. Unfold a paper clip insert it into the hole and push firmly this will open the door. If not you can remove it from the computer and unscrew the sides allowing you access to the insides.
Thanks J
Nov 25, 2007 | ASUS (CRW5232A/QTWHT/G) CD-RW Burner
RCA RP4010 Clock Radio Logo
127 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
