Question about Acer Aspire 5610-4648 Notebook
Bios upgrade bios for aspire 5610z
My present bios will not accept 2 2GB modules to upgrade to 4GB --- It hangs up
  • rsp314 Feb 08, 2008
    Finally got Acer help.
    The aspire 5610 will not handle more than 2GB total.
    The manual is wrong in stating it could take 4GB.
    Thanks to every one that tried for me.
  • pyroboy4206 Feb 10, 2008
    Similar problem, mine won't recognize the 2gb upgrade. i am having this problem.
I had the same problem. I am running vista but it work run on 2 2gb modules but since installing sp1 for vista i now can have 1 2gb module and 1 512mb module together giving me 2.5gb so better than thought it would at 2gb!
Posted on May 24, 2008
    Sergeant:
    Champion:
  • 243 Answers
If you go to the acer site there are utilities to update the bios
http://support.acer-euro.com/drivers/utilities.html#BIOS
Make sure 11% that you flash the correct bios as the wrong one will render it useless. Also make sure that you are plugged into the mains when doing it and pray that there isnt a power cut during the flash :)
Posted on Dec 29, 2007
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
Upgrade memory asus pro70c
Keep in mind that a Windows 32 bit system will only accept up to 4GB, but utilize only 3GB. Something to consider before you purchase.
Check your manual.
http://www.manualowl.com/m/Asus/Pro70C/Manual/262110
64 bit is OK to increase.
Nov 21, 2012 | Computers & Internet
Installed 4GB upgrade in optiplex 330 still only 2GB memmory
Your BIOS should automatically detect your new RAM when your computer starts, try starting your computer after removing your old RAM module, if it starts, you need to update your BIOS to use 4GB. If it doesn't start, you either have a faulty RAM module or a faulty connector on your motherboard. Insert the new RAM module into the slot the old RAM module was in, if your computer still refuses to start, you have a faulty RAM module which should be returned, if it does start, it's the connector on the motherboard, and only replacing the entire board will fix the problem. However, it's worth noting that your motherboard will only support RAM modules of 2GB or less, the above was written with the assumption you're adding an additional 2GB module to your Dell computer.
Dec 24, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
I have a new G560 lenovo laptop with 2 gb memory. I want to upgrade to at least 4 gb. Will this computer accept two 2gb memory modules, one in upper slot and one in lower slot or do I have to buy a 4 gb...
Yes, laptop will accept two @ Gb memory modules. Maximum capacity of RAM for G560 is 4gb.
Hope this will help... Your response is very much appreciated...
Nov 08, 2010 | Computers & Internet
I have a Dell Inspiron 531s that presently has
yes, the system will accept PC2-6400 RAM
Depending on the processor installed, there may not be any increase in performance.
Reference:
http://www.crucial.com/store/listparts.aspx?model=Inspiron%20531s
Dec 18, 2009 | Dell Computers & Internet
My Averatec A3300 does not like the 1GB memory module which I used to replace the supplied 512MB unit. The computer becomes unstable and invariably ''hangs''. The 1GB module used was the one recommended by...
Sounds like the memory stick isn't compatable/wrong voltage or is faulty.A bios upgrade you can get at the Averatec website support but its unlikely it will help though.
Oct 07, 2009 | Computers & Internet
Acer 9300 bios upgrade failed
Hi!
I have the same problem, and my problem was that I have installed 4GB ram and that ram modules wasn't accepted with the new bios. So I installed the old modules and it all worked again, downgraded the bios to one version older and installed my 4GB ram modules and it all worked.
Hope that's your problem too.
Good luck
Feb 14, 2009 | Acer Aspire 9300 Notebook
START MENU AND KEYBOARD PROBLEMS ACER 5610z
Check to see if this happens when booting into safe mode.
Jun 05, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-4648 Notebook Logo
229 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
