Home | Epson | Stylus CX4600 All-In-One InkJet Printer | Epson CX4600 printer - w...
Epson Stylus CX4600 All-In-One InkJet Printer
Problem for Epson Stylus CX4600 All-In-One InkJet Printer
Epson CX4600 printer - will not print color at all
By devensonru4h on Oct 12, 2009
I just installed a used Epson CX4600 printer with driver downloaded from Epson.com. I installed 4 new Epson ink cartridges. Black only - no color in printouts. I've cleaned heads 3 times. Still no color - only black. What am I missing or what can I do? I got the printer from a neighbor (who I trust) who said it was working. I only installed one driver. I did not install any other drivers (for the scanning, copying, etc.) I wanted to make sure the printer worked first. Is there a separate driver for use of the color cartridges?
Comments:
Oct 13, 2009
- Thanks for your comment. But I didn't see any protection tape on any of these cartridges. Like I mentioned, the black worked OK without doing anything to it. That's why I'm thinking I'm missing something on the software side of things. I could understand if one or maybe two colors didn't work or that they might be splotchy but to get no color at all seems like a software issue. Also, the ink levels are going down on all colors when I do the head cleaning routine. And when I remove the cartridge and touch the point that pokes into each cartride, there is a drip of each color (as I'd expect if ink was being released). Any more suggestions?
Solution #1
posted on Oct 12, 2009
Somewhat Helpful)
dell-net
Rank: Wiz
Rating: 85%, 219 votes
no it should work at it is. if you installed the plug and play printer driver. have you removed the protection tape from the inc tubes?
Comments:
Oct 13, 2009
- try to write a test page from the printer, you should hold down one button on the printer until it prints a test page.(dont know which.) I think you find it in manual. I will see if I find it.
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus CX4600 All-In-One
Questions and Unsolved Problems for Epson Stylus CX4600 All-In-One
Do you recommend Epson Stylus CX4600 All-In-One InkJet Printer?
Answer
Answer
When I print from the computer everything is fine, but when I try to copy something I get gaps in... (More)
Answer
all lights on panel light up when I push the on button
Answer
when sending a document to be printed on my Epson stylus cx4600 I get the message on my moniter... (More)
Answer
all of my lights on the left panel are blinking, with an E in my page number display. new ink... (More)
Answer
My Epson Stylus CX4600 prints offset colors (not on top of each other) , all cartridges are new, and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus CX4600 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
