CD and DVD Burners
Problem for CD and DVD Burners
Generic problem for all CD and DVD Burners
DVDRW does not recognise any media
By redfraggle77 on Oct 12, 2009
My DVD-RW drive is not recognising any media at all. I have tried blank CDs, blank DVD-R and DVD+R, Movie DVDs, Music CDs. I have tried multiple brands of blank disk as well. It will not read, format or burn to any disk
It is a TS-L632H Slim 8x DVD-RW and has been working fine until today. Its about 1 year old.
The error message I get is ''Please Insert a disk into Drive E:''
I have already tried the following:
- Uninstall my DVD-RW drive (via Device Manager) and let it re-install automatically
- Updated the Firmware
- Removed all burning software and iTunes
- Re-installed Roxio (as was the software pre-installed when laptop delivered)
What else should I do?
Comments:
Oct 12, 2009
- Really don't want to buy another unit. Any other options?
Oct 12, 2009
- Did try this before raising the request but there wasn't any Upper/Lower filters to delete.
Solution #1
posted on Oct 13, 2009
Somewhat Helpful)
marked
Rank: Guru
Rating: 86%, 932 votes
This can be a problem with the lens of the media drive that you have, the first thing that you can do here is to run a lens cleaner on it, you can get it from any electronic store near you, but after running a lens cleaner and still the same problem a lens replacement is needed for this unit....
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 12, 2009
Somewhat Helpful)
rulds2008
Rank: Guru
Rating: 86%, 1074 votes
This is due to a bad pickup laser on this its easier and more cheaper to replace then to go ahead and fix you can pick these up faster and better at any computer store and there relatively easy to install.
You can try a cleaning kit to see if that shores it up if it does you saved what $45-$50 bucks but if it does not well your most likely better off getting another unit. This is my expert advise I do Thank you for using Fixya.
Please click the ACCEPT BUTTON
Best regards
Rulds2008 Fixya's Expert in computer repair
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
lyzmorato
Rank: Guru
Rating: 85%, 216 votes
Hi!
You maybe one of the hundreds of users experiencing this issue with optical drives. Fortunately, There is still a fix. This may apply to your computer now and that is to remove the Upper/Lowe Filters. Please follow the instructions below:
Microsoft Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this image, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this imageIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Microsoft Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
If you still need further help regarding this problem, please post a comment.
Thanks!
Was this helpful?
Yes
No
Popular Solutions for CD and DVD Burners
Questions and Unsolved Problems for CD and DVD Burners
Answer
I need an internal cd/dvd burner drive tray where to buy one
Answer
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD... (More)
Answer
dvd duplicator disc in the trays but it says target drive not ready
Answer
I just got a Que!Fire 24x10x40X CDRW and I plugged it into my mac os x v10.4.11 with a firewire cord... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For CD and DVD Burners:
Top CD and DVD Burner Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD and DVD Burner Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
