Question about Toshiba 42H81 42" Rear Projection Television
Convergence adjusting I have a 42 rear projection toshiba.  There are red lines thru out the screen. I can get to the convergence grid, select to adjust red lines, and get the nine position grid but it will not allow the adjustments to any position.
  • fed-uptv Jan 01, 2008
    i have the same but on the 46". the screen bends at both top corners and convergence does nothing. any ideas?
    Problem Solver:
  • 3 Answers
You need to replace the 2 stk-110's mounted to the heat sink
i had the same problem
and works pretty good now
Posted on Dec 28, 2007
Mitsubishi ws-48311 blue and yellow shadows
I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.
If they will not adjust the set needs the convergence circuit repaired.
For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.
Look first to see if this is your problem.
SD TECH
Apr 22, 2012 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi Rear Projection WS
5ebe434.jpg A projection television and a convergence control method thereof are provided. The projection television, which magnifies images displayed on cathode ray tubes (CRTs) for the colors red, green, and blue using lenses and projects the magnified images onto a screen, includes a convergence control apparatus capable of adjusting the convergence while an input image signal is displayed, the convergence control apparatus including: an image signal decoder which processes the input image signal to generate a data signal, horizontal and vertical synchronous signals, and a start signal indicating the start of either the horizontal or vertical synchronous signal; a convergence control unit which normally projects an image signal output from the image signal decoder onto the screen and performs convergence control using a predetermined region of the screen displaced from a visible region of the screen according to a convergence control command; and a main microcomputer which inputs the convergence control command to the convergence control unit when the start signal is input from the image signal decoder, stops the convergence control when a completion signal is input from the convergence control unit, and performs a control operation to continuously display the image signal during the convergence control.
the pro in convergence control circuit only..so better change tat..
Sep 21, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi big screen rear projection tv the blue
The tv 100% have convergence problems,it dead.If any colors lines don't matches or stay in the - + convergence grid.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv conververgence board must have these parts changes to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Mitsubishi Televison & Video
Convergence setup for toshiba 42in projection
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 06, 2010 | Toshiba 42H83 42" Rear Projection...
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 41h81 green convergence problem
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apr 07, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba v43j22p 42" red shadows and lines over screen
6b5ee7e.png You may have a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 02, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 42h82 convergence resistor and pico locations
yes better.  you need schmatic. servicemanuals.net.
Dec 13, 2008 | Toshiba 42H81 42" Rear Projection...
Convergence
you need to replace both convergence ICs they are STK392-110 you can get replacements at the following link with free installation instructions so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Aug 23, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
