Question about Toshiba SD-5000
New Player freezes up on or after track 12
I purchased this player about a month ago... Great picture and all. But approximatly of the 90% movies I've played on it froze on track 13, 14, or 15. And none of the tracks after this point will play. At first I thought it might be the DVD's (rentals), but after having the same thing happen with a brand new DVD right out of the package I seriously suspect a problem with the player. Any ideas/solutions/suggestions?
  • Anonymous Nov 06, 2008
    i have the same exact problem. Freezes up on track 12-15. its not the dvd. i got it to play those tracks on one dvd by going to the scene selection menu, but this only worked on one dvd.
  • Anonymous Mar 08, 2009
    Mine freezes up also. I put it away and bought a Philips, which I never had any problem with. So after a couple of months, I took it out of storage and hooked it up. Guess what, froze up. Now I remember why I stoped using it. Toshiba player sucks. Buy anything else!
This is the same response to another post
the unit i purchased ran great for about 2 months then the video started to freeze. power cycled solved the problem initially, but when power cycling did not cure the problem, i started shaking and tapping the unit. at a point of throwing the unit away - took the cover off to see what's inside. with the cover off, it ran just fine . put the cover back, ran ok for a while then started freezing video again.
twisting the unit appears to make it function..
my solution that appears to work for my unit. .
loosen only the two back screws holding the plastic drive mechanism down to the bottom plate (chassis) assumption is that the metal chassis was twisting the drive mechanism and offsetting the photo pickup.
this has worked for the past 2 weeks without a problem.
Posted on Jan 22, 2008
CD/DVD player freezes in mid-track
if still the same problem you encountered then its under warranty it was in titled to replace the unit since you can not use in good condition. or they might thorough check and test the unit before send it back to you, might the problem was factory defect.
Mar 22, 2012 | Televison & Video
BD-P1600 will play DVD-R with no problems up untill the last chapter of a movie then the picture freezes up and wont finish playing. is there a solution? Updated firmware about 3 weeks ago.
Either the Laser needs to be cleaned or it needs to be replaced. To clean, purchase a DVD player cleaner that uses fluid. roughly 20.00 run it a couple times and test. If it works, great. If it doesn't, replace the unit. It's cheaper than the repair. Hope this helps
Jan 13, 2011 | Samsung BD-P1600 Blu-ray Disc Player
I have had my sumvision dvd player now for a few months and it keeps freezing periodically when watching a movie, sometimes its starts and then freezes, this is happening always now, even though I have...
The problem is the laser pickup assembly in the dvd, If it freezes the stepper motor which drives the worm gear along with the laser carriage is the problem, the precision in tracking is critical and any interference causes the picture to freeze. If you have any warranty on the unit I would encourage you to take it back for possible exchange, because it will get worse and finally become unusable.
Jan 08, 2011 | Sumvision Televison & Video
I have a Sylvania SRD3900 DVD Player / VCR Combo that I purchased about 6 years ago. The VCR part is causing problems. When I try to play movies the picture is distorted with no sound, but it plays back...
The tracking needs to be adjusted. Sometimes it's a knob on the VCR, and sometimes it's a control on the remote. Adjust it for the best picture, and the sound shoud be restored.
Good luck, and hope this helps..
Nov 01, 2010 | Sylvania SRD3900 DVD Player/VCR
I have a Sony DVD player hooked up to my TV. The player is approximately 5 yrs old. It seems that when its on for 15-20 minutes, the movie in it freezes. Even if the movie is brand new, the message on...
Well I wont be as quick to buy a new player yet!!
Firstly i would clean the lens and try running it the the cover off.. That should give you some time. But yes eventually you will need a player. Also the movie that freeze in the same place every time, try that on a neighbours or friends player to be certin it works :)..
I always try to avoid spending unnecessary cash or delaying it for as much as i possibly can. Hopefully taking the cover off will allow it to cool better giving you a few months to get things in order.
Nov 13, 2008 | Televison & Video
Samsung yp-k3 player
You will need to contact Samsung direct. Unfortunately it costs $35 to have it assessed. If it was bought less than 12 months ago you can provide proof of purchase or a Stat Dec and confirm the place of purchase and the service centre will process it for you. If you have the serial number, you can use that to track the purchase date. The locations for repairs can be found on
Aug 18, 2008 | Samsung YP-Z5 MP3 Player
Do not read the movies
dvds and cd's have new format out now for anti piracy you have to go out and buy new dvd drive 8 months ago bought a dvd player not just a month ago found out they changed the formats on dvd's and cd's this cant be changed or modified
Jul 07, 2008 | Cyberhome CH-LDV 700B Portable DVD Player
Picture freezes
caribjim were you able to fix the problem
Jan 28, 2008 | Panasonic DVD-LS90 Portable DVD Player
No picture
YEPPI! It works! Thanks for helping me fix this problem!
Mary in WV
Mar 26, 2006 | Audiovox D1708 Portable DVD Player
Toshiba SD-5000 Logo
126 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
