Your symptom sounds like a damaged convergence IC.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values. There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need. Their site is http://www.andrewselectronics.com/welcome.aspx And their phone number is a 24-Hour Order Desk: (800) 274-4666 I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue. If you need further assistance please comment to this post and I will try to help you further. asnowman
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-65809 65 in.
Mitsubishi WS-65809 65 in. Rear Projection Television
The TV will work for a while and then the picture will get lines in it and then the tv will shut...
(More)
The TV will work for a while and then the picture will get lines in it and then the tv will shut itself off.
My TV picture just lost normal viewing and now I see grean lines going across the screen at an angle...
(More)
My TV picture just lost normal viewing and now I see grean lines going across the screen at an angle and the picture is moving sidways across the screen I just replaced the IC chips a couple months ago. What would cause this issue?
The TV won't turn on. It clicks on and then clicks off within a second or so. One time it wouldn't...
(More)
The TV won't turn on. It clicks on and then clicks off within a second or so. One time it wouldn't turn off and wouldn't respond to any input such as volume or channel control
