Question about Mach Speed TRIO Onyx MP3 Player
Won't turn on
When I was updating my Onyx my brother pulled it out of the computer. Is there any way I can make it turn on?
Re: Won't turn on
This is from Onyx web site. It worked perfectly if you follow the istruction!!!!!
This Process is generally required after a failed firmware update. 1. Connect your ONYX to your PC, and go to your device manager 2. In your device manager, you will find Player recovery device, or recovery class device (depending on your OS version) 3. Right click on the driver and select to uninstall the driver. 4. Disconnect the player form your computer, and move the ON/OFF switch on the device to the OFF position 5. Press and hold the PLAY button on the player. While holding the PLAY button, connect the device to your PC and continue to hold the PLAY button for 5 seconds. 6. Your computer will either run a found new hardware wizard, or give you a hardware recognition message. If the found new hardware wizard is displayed, select "Yes, this time only", and "search automatically" 7. Once the found new hardware wizard has finished loading drivers, or the hardware recognition message has completed, please go to 8. read the entire page, and input your ONYX Identification number. This is the number on the rear of the player located to the right of the serial number sticker, and will begin with the number "07". Select I Agree. 9. Follow the instructions on the following page to reactivate the firmware on your player. if you have any problems or questions while following the above procedure, please contact our technicians at (580) 272-0035.
Posted on Jan 02, 2008
Re: Won't turn on
1-Uninstall it from windows device manager
2-turn it off
3-plug it to USB
4-Turn it on again for 5 sec.
5-go to the website of onyx
6-search for firmware update for this type
7-enter the code printed on the back of the device next to the white sticker
8-download an run the firmware
9-within 2 minutes it finhes update
10-unplug the plyaer from USB
11-Plug it again or press play button for 5 sec.
I hope it is usefull.
Posted on Dec 30, 2007
0 characters
3 Points
How do I turn on an onyx mp3 player
First, make sure that the Mach Speed Trio Onyx MP3 player is fully charged (if you use a rechargeable battery) or insert a new AAA battery. Then press and hold the Play button for 5+ seconds. This will turn off the MP3 player if it is on.
Retrevo has the manual for the Onyx here: . You will need to enter a code to access the PDF.
I hope this helps.
Oct 14, 2014 | Mach Speed TRIO Onyx MP3 Player
What's your problem?how can i put music in my onyx mp3
What you should do is check your PC Control Settings and then under devices, try restarting the PC and make sure that nothing is in the cable outlet, make sure that you go under "My Computer" once you restarted the computer.
Nov 14, 2011 | Mach Speed TRIO Onyx MP3 Player
Hi, i don't know how to get my mp3 player (onyx) to work. when i plug it to my computer to charge, it blinks says ''loading''. after a couple seconds of blinking that message, it turns itself off. it...
try getting a different usb cable the one for the razor works just fine with it and it's probably out of battery thats all i can say its just a suggestion hope it works
Feb 08, 2010 | Mach Speed TRIO Onyx MP3 Player
Mach Speed TRIO Onyx MP3. How do I charge it?
Try to find the charger and plug it in the MP3. Maybe the charger you have to pLUG IN one end to the computer and the other part to the MP3.
Dec 25, 2009 | Mach Speed TRIO Onyx MP3 Player
ONYX Player doesn't come on
my onyx mp3 player will not turn on unless its plugged min to a charger
Dec 28, 2008 | Mach Speed TRIO Onyx MP3 Player
I can not put videos on My ONYX 2GB
You can load video files onto your player by plugging the player into your computer. It should try to autorun at which point you should select view folders.
If it doesn't autorun just go to Start>My Computer>Removable Disk
Locate the VIDEO folder and put your movie files in it without any subfolders.
Properly disconnect it from the computer, turn the player on, and press the menu button and select video from the list and play.
Dec 26, 2008 | Mach Speed TRIO Onyx MP3 Player
Blank screen after updating firmware
It was $30 dollars, my suggestion is to smash it with a hammer and just buy an ipod. I have 2 friends with 2 different models of onyx players, The 2GB is now dead with a white screen, the others battery dies in 25 minutes.
Dont buy offbrand ****..
iPod, Sony, Zune. Best quality. I still have my original ipod from 4/ 1/2 years ago and it still works.
Jun 09, 2008 | Mach Speed TRIO Onyx MP3 Player
I cant put videos on my player
i put videos on my onyx but when i turn it wont have the videos.what do i do?
Apr 28, 2008 | Mach Speed TRIO Onyx MP3 Player
Mach Speed TRIO Onyx MP3 Player Logo
264 people viewed this question
Top Mach Speed MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Mach Speed MP3 and Digital Media Player Expert? Answer questions, earn points and help others
