Question about Bose 3 2 1 GSX System
Bose 3-2-1 cd stuck in closed position
I have a bose 3-2-1 and the cd will not open
  • 52 Answers
Take it to Bose dealer or service center near you.
If you have technical knowhow, try the image enclose. make sure its the same model.Bose 3-2-1 cd stuck in closed position - 5f18d64.jpg
Posted on Jan 03, 2008
What's your problem?Bose wave system cd doesnot eject
Contact the nearest authorised service center for Bose. CD loading mechanism has been struck. You have to open it. It is a skilled work.
Jun 09, 2012 | Bose & Wave& Music System
Cd opening
Loader mechanism to your set has the fault. Contact the nearest authorised service center for Bose to rectify this fault. It will be very difficult to get the loader mechanism of Bose, from open electronic market.
Mar 30, 2012 | Bose Lifestyle 38 System
Bose 321 cd/dvd tray stuck closed. Will not open.
Hello
Check its loading belt for borken. you have to open this deivce. an experienced service technician only can open Bose sets. So get this set repaired by any one well experienced with servicing Bose systems. OK.
Dec 28, 2011 | Bose (321GS) System
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
Stuck terminal tab
I was able to pry the stuck tab open with a small flat head screwdriver. After a number or repetitions of that process, plus some repeated pushing on the tabs, they started working normally.
Aug 05, 2008 | Bose Acoustimass 3 IV System
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Bose 321
    To get my unit open I hit on/off and the source button at the same time. Then open showed up on the 3-2-1 window, then I hit the eject button. It works fine now.
    May 07, 2008 | Bose 3·2·1 II System
    Please kindly check if this is d model of your 321
    Nov 13, 2007 | Bose 3 2 1 GSX System
    Cd changer
    Could be some dirt on mechanism. Try to open cover, remove disc and clean it. Unplug it from power first, of course!
    Oct 03, 2007 | Bose Lifestyle 25 System
    Bose 3 2 1 GSX System Logo
    126 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
