Question about Pioneer SD-P50A3-K TV
TV stay on standby
The TV upon turning it on the green power light briefly lights like 2 seconds then the TV goes into standby red light on. I currently have no cable or antenna hooled to tv.
  • 1070 Answers
SOURCE: tv refuses to turn on
your tv is defected need to take in to the tech for repairs.power supply problem or related circuit.good luck
Posted on May 27, 2007
  • 1153 Answers
SOURCE: Pioneer SD-62A5 has red standby light, won't turn on
Check C258 video assy.
Posted on Aug 16, 2007
SOURCE: pioneersd533hd5
(3) 4 amp 150 volt fuses (slow burn), and (2) 10 amp 250 volt fuses (ceramic), all replaced. $5.50 worth of fuses DID THE TRICK. Radio Shack has them both. If you can't find a 4 amp 150 volt, 5-6 amp up to 150 volt fuses work just fine!
Posted on Sep 03, 2007
  • 790 Answers
SOURCE: SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Posted on Oct 22, 2007
same problem here
Posted on Sep 25, 2008
  • 136 Answers
SOURCE: Power problem (switches to standby)
its the problem of the ics on the main power supply board
Do the IC heat sinks get warm??
If they do not, check fuses F852 - 2AMP, F853 - 1.25AMP, F850 & F851 - ALL 5AMP on the power deflection pcb. THESE ARE NOT GLASS FUSES. They are usually about the size of a 1 watt resistor and either green or orange in color. They are soldered in. The nomenclature is printed on the component side of the board. They are all about centered on the opposite edge of the PCB as the high voltage transformer.
If you have cleaned up the mess you describe you most likely have one of these fuses blown.
if dont have any technical knowledge its advisable to call a technician as it is worth getting it fixed.
Posted on Oct 12, 2008
0 characters
1 Points
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I'm assuming that it is an error code. The red
colour wheel issues and defective lamp replacing lamp and light engine color wheel cos its worn out
Jul 07, 2013 | Projection Televisions
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Pioneer SD-P50A3-K TV Logo
16 people viewed this question
Top Pioneer Projection Televisions Experts
Jaime Hernandez
Level 1 Expert
Are you a Pioneer Projection Television Expert? Answer questions, earn points and help others
