Question about Amana ALE331RAW Gas Dryer
Start cycle does not respond
When trying to start the machine, it makes a click noise and does not respond
  • Amana Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Posted on Sep 30, 2010
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...'t+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ... > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
Dryer comes on but won't start any cycle. What could be causing this?
Samsung Dryer Won't Start - Model DV448AGPXAA - Repair ...
Samsung dryer won't start? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Dryer Won't Start - Repair Parts -
If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a ...
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
Oct 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer might not be starting. ... If it makes noise but won't start trying spinning the drum empty ten times then close door and try it. ... I changed the door switch and still gives code AU. any suggestions .... thermal fuse everything seems good except my dryer won't come on!!!.
Samsung Dryer DV431AEP - won't start cycle - Appliance Repai
Jan 10, 2016 | Samsung Dv410aew 7.4 Cuft 11-cycle Steam...
Machine makes the clicking noise when you press the start button but the machine wont start, It has a faint humming noise.
G'day, be sure water is on, try changing settings from hot to cold or vis-versa to test out each solenoid (these are electrical taps at back of machine which hoses connect to). Be sure water is on. And then make sure door is closed to make sure it is not the trip switch (you can also try machine on spin cycle to test if the trip switch on door is problematic). If the machine seems to still spin, it would seem that water is just not getting in... Try changing water level... this could be faulty and be telling the machine that its full, but i doubt it as it would still run dry. Check water is on
Hope this helps, let us know how u get on
Aug 08, 2011 | Washing Machines
Will not start. have jumped battery. will get enough juice to make the key in ignigtion warnig bell but will not turn orver
when you cycle the you hear a fuel pump noise it will be on for 3 seconds, cycle it. you should hear it, if you dont go to the battery junction box fuse area, and check the fuses. and make sure the fuel pump fuse is not shorted out. also when you cycle the key to ACC do you hear a click in that box area? This vehicle is ASD relay control ill keep my eye on this post if you repond to me i ll respond if some one else you respond to let them help you
Apr 30, 2011 | 1997 Dodge Neon
Started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Jul 13, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Washer WPSQ4160T
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Amana ALE331RAW Gas Dryer Logo
76 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
