Rogers commander code for Samsung model V6700
Can not find code for digital box for commander to turn on VCR. Tried everything.
  • simonwood Mar 14, 2009
    I can't find the code to access the vcr commander and tape programmes.
  • 579 Answers
What is the model number of the remote or commander?
Posted on Dec 28, 2007
How to program a rcr804bfdr to a sanyo tv
Programming the RCA RCR804BR or RCR804BFDR Series Remote Control
Programming with Direct Entry:
To program your remote to control up to four components, follow these steps:
  1. Manually turn on the component you wish to program the remote to operate.
  2. Find the four-digit code for your brand of TV, VCR, DVD, satellite receiver, cable box, or digital TV converter in the enclosed code lists.
  3. Press and hold the CODE SEARCH key until the indicator light turns on.
  4. Release the CODE SEARCH key.
  5. Press and release the TV, VCR or SAT·CBL·DTC key. The indicator light blinks and then remains lit. Note: DTC references digital TV converter. To program the DVD·AUX key: Press the DVD·AUX key. To control a DVD, press the VCR key. To control a TV, press the TV key. To control a satellite receiver, cable box, or digital TV converter, press the SAT·CBL·DTC key. The indicator light stops blinking and remains lit.
  6. Enter the four-digit code, using the numeric keypad. After the code is entered, the indicator light turns off. Note: If the indicator light blinks multiple times, you've entered an invalid code. Start from step 2 again.
  7. Aim the remote at the component and press the ON·OFF key. The component should turn off. Note: If your component does not respond, try all the codes for your brands. If the codes do not work or your brand is not listed, try the Code Search Method that follows.
Programming with Code Search:
If your TV, VCR, DVD, satellite receiver, cable box, or digital TV converter does not respond after you have tried all the codes for your brands, or if your brand is not listed, try searching for your code via the Code Search Entry Method. To program your remote via the Code Search Entry Method, follow these steps:
  2. Press and hold the CODE SEARCH key until the indicator light turns on.
  3. Release the CODE SEARCH key.
  4. Press and release the component key you wish the remote to control- TV, VCR or SAT·CBL·DTC key. The indicator light blinks once and remains lit. Important: Find the ENTER key on your remote (don't press it yet). You will need to press this key quickly in step 6 below. To program the DVD·AUX key: Press the DVD·AUX key, followed by the component key you wish the DVD·AUX key to control. For DVD, press the DVD·AUX key, followed by the VCR key. For an auxiliary component, press the DVD·AUX key, followed by the corresponding component key ( TV, VCR, SAT·CBL·DTC ).
  5. Press and release the ON·OFF key until the component turns off. Important: You may have to press the ON·OFF key up to 200 times.
  6. As soon as the component turns off, press the ENTER key within 4 sec- onds. The indicator light turns off. Note: If you wait longer than 4 seconds to press ENTER, the remote goes to the next code-you will need to start the code search from step 1 again.
Dec 24, 2014 | RCA Televison & Video
Tip
How to program your RM-V310 Sony Universal
Step 1: Entering the Code Number
1 See the supplied "Component code numbers", and find the threedigit
code number for the desired component.
If more than one code number is listed, use the number that's
listed first to complete the steps below.
For example, if you're setting up a Philips' VCR, you would use
the code number 035.
If your component isn't listed, see "Searching for the Correct
Code."
2 While pressing the SET button, press the
POWER button.
3 Press the button of the component that
you want to set up.
Note
On the VCR, CBL, SAT, AMP, CD, and DVD buttons, "video cassette
recorder", "analog cable box", "digital satellite receiver", "receiver",
"CD player", and "DVD player" are assigned respectively at the
factory. But you can also assign other components on these buttons.
For details, see "Changing the Component Type on the VCR, CBL,
SAT, AMP, CD, and DVD buttons."
4 Enter the component's code number.
For example, if you're entering the code
for a Philips VCR, you would press
5 Press and release the ENT button to store
the code number in the Commander's
memory.
6 Go to "Step 2: Checking if the Code Number Works" to finish
setting up.
1 Power on the component you want to set up.
2 Aim the Remote Commander at the component and press a button
to check if that button works.
For example, press the POWER button to see if it works on your
component .
3 Check that the other buttons of the Commander is operating the
corresponding functions of the component.
You can write down the code number on the label inside the
battery compartment lid.
If the Commander Doesn't Seem to Be Working...
• First, try repeating these setup procedures using the other codes
listed for your component (see the supplied "Component code
numbers").
• If - after trying all the codes listed for your component - you still
cannot get the Commander to work properly, try the search
method described in "Searching for the Correct Code."
These instructions came from the Sony RM-V310 Operating Instructions Manual. To Download the Full manual for FREE click HERE>
on Oct 07, 2010 | Sony RM-V310 Remote Control
My vcr recorded my shows before i switched to a digital adapter now i cant get it to record anything ive tried everything
If the digital adaptor is connected to your TV, then the VCR will not get any signals to record. The VCR will also have to be converted, by adding another digital box, unless the first box has two digital tuners! You can connect another box if the VCR has two scart sockets, the second box connected to the other scart socket. To record after connection, leave the box on, set to the channel you want to record, and set the timer on the video. However when selecting the channel to record make certain that you select the scart socket with the box connected to it. Also make certain (if the VCR has it) PDC is set to OFF as it no longer works.
This way you can record shows while watching anothe channel.
Jul 16, 2011 | RCA VR525 VCR
How do i record from a vcr tape to a dvd on a sansui dual deck vcr dvd recorder?
If it is a combination VCR/DVD player,they usually can't do it.If you get a separate VCR player from a friend or neighbor,you can connect the VCR output to a cable box input,cable box output into DVD input,or if the DVD recorder has a digital tuner you can plug the VCR output player straight into the input of the DVD recorder.DVD recorders REQUIRE some form of digital input.That is why you need to route a VCR player through a cable box or the DVD recorder needs a digital tuner.If you are not sure if your recorder has a digital tuner,call sansui,they will know.I tried to find Sansui home and I found everything BUT DVD/VCR.If you have a manual it will be in there,or it may have a phone number on a label(back or bottom probably)of the unit.Good luck!Greg If you want to send me your model number,I will research it further too.It is up to you.
Aug 06, 2010 | Televison & Video
Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Jun 29, 2009 | Allegro DVD/VCR ABV511
Ambiuous Information out there
I kind of think the people that wrote the manuals didn't bother hooking up a unit. Here is some help.
The converter box is nothing more then a tv tuner that picks up a digital signal and converts it into analog so your tv can view it.
The vcr, to record programs has to be set to channel 3 or 4 (whatever the converter box is broadcasting on) to record. The converter for the vcr will have to set to whatever channel you want to record from every time you use the vcr and left on as this is the only was the vcr can pick up a signal. Make sure the power saver on the converter box is set to off.
If your tv converter box has digital pass through, all you have to do is turn the tv converter box off and it your tv should pick up the singal from your vcr when you play tapes. You also use this method to access the menu on the vcr.
Jun 04, 2009 | Insignia Digital-to-Analog Converter for...
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
Digital reception
If you do not have cable/satellite ,Yes
Dec 11, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Magnavox 20" tv with vcr and dvd, Model #CT202MW8
call comcast they should know the correct code its there unit.
Jan 17, 2008 | Philips Magnavox 20MC4304 20 in....
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
