Question about Gateway MX6442 Notebook
WILL NOT BOOT UP - LOST THE OPERATING SYSTEM
I NEED TO GET MY COMPUTER TO BOOTUP...IT LOST THE OS .... I CAN'T FIND MY DISC AT THE MOMENT....WE JUST MOVED... I GUESS I LOST EVERYTHING, BUT I WILL BE HAPPY JUST TO GET IT GOING AGAIN, AND I WILL REINSTALL DRIVERS OR WHATEVER BUT I NEED TO GET IT GOING WITHOUT THE DISC...IT'S A GATEWAY MX6442 ...THANKS
Gateway zx4351 operating system missing
When did you get this Gateway? Where did you get it? I assume you mean that it has no OS, cause Gateway does NOT make an operating System. Need more details, please!
Nov 08, 2014 | Computers & Internet
Operating system not found
sounds like its lost its windows bootup.or the hdd has come lose.
has anybody tryed to install windows again,or has it been droped.
but what ever happend its hdd thats at fault by the sounds of it.
Apr 01, 2014 | Acer Aspire Computers & Internet
How to reformat a laptop
This may vary depending on your laptop make and model. The standard method for reformatting any PC (Desktop or laptop) is to insert your manufacturer provided Operating System disc into the CD/DVD ROM.
Your submission says this is a Dell laptop so the moment you turn on the computer begin pressing F12 to trigger the one time boot menu. Insert the Operating System disc into the computer while you are at the menu then select boot to CD/DVD ROM (the actual choice will vary depending on your hardware).
Since you presumably have an Operating System installed you may need to interact with the boot to cd/dvd to make sure that you do indeed boot to the disc. Once you have booted to the disc follow the on screen instructions to format the system and re-install your Operating System
Nov 22, 2011 | Dell Computers & Internet
Test media failure Operating system not found
Hello zyrenic, it seems that the "problem is the [Operating System] is not loading correctly." The CPU is trying to find or fix the Bootup into 'loading' the OS!
Follow these instructions
To get the Computer to "Boot into the OS and "Loading Windows."
  • Restart the Computer
  • Next, just before the [Page] that you mentioned, "Displays," {Press the F12} button.
  • This will open the [Priority Boot Sequence] window.
  • There will be a "list" of (Devices), Optical Drive / CD, Sata / HardDisk Drive, or USB...
  • I do not know the "Configuration of your Operating System" or the Drive: that "holds the Boot [NTLDR] files.
  • It may also hold the "Master Boot Record" or Boot.ini file?
  • So, what you need to do is give the Drives a "Priority Boot Sequence," meaning , you will 'place' the Drives in the 'order' of Bootup [First] listings.
  • You will use the {Arrow buttons} to 'move the "Drives."
  • More than 'likely' it will be the {HDD, or Optical Drive}.
Try each, and hopefully the Computer will make it to "Windows," and you can "Login!"
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 17, 2011 | Computers & Internet
Hi! im using windows 7 starter, can i used vista as my new os?
ye you can, it mean you must downgrade your pc, use vista cd to install it, but you may lost your data at drive C: you must back up your drive c: data before install vista
i hope this helpful
thank you for using fixya
Jan 30, 2011 | Computers & Internet
Get a ? when trying to boot up--
This indicates that it cannot find an Operating System or further more a drive to boot from with the OS on it. You can try Holding the Option/alt key down at bootup to see if it gives you any boot options. Here is a list of a few other scenarios you can attempt :
1. Insert the software that came with the machine, then restart the computer while holding the C key. (If you do not have the Install desk at least perform the Safe Boot in #2 below.) a. The computer should start up from the disc...then b. Choose Disk Utility from the Installer menu. (Important: Do not click Continue in the first screen of the Installer. If you do, you must restart from the disc again to access Disk Utility.) c. Click the First Aid tab.
d. Select your Mac Operating System volume.
e. Click Repair. Disk Utility should now check and repair the disk.
2. Then Safe Boot , (holding Shift key down at bootup), run Disk Utility in Applications>Utilities, then highlight your drive, click on Repair Permissions, reboot when it finishes.
Dec 13, 2010 | Apple Power Mac G3 Desktop
Wont boot and says that no operating system can be found
Get a recovery disc for your computer (OS or a partitioning/utlity tool). You need to find out if you lost the MBR (the where is the OS information), the partition, or if the hard disc failed.
It's very likely that any repair attempt may reformat your hard disc. So consider a Live CD rescue tool and backing up if you haven't been consistently doing so. (Attach a USB hard drive or external optical drive for the backup data.)
Good luck and I hope this helps.
(who has a computer smart relative who reformatted the computer without salvaging the data to find out the hard drive was failing and that was why it lost the MBR the first time.)
Apr 17, 2010 | IBM ThinkPad A31 Notebook
Fujitsu esprimo v5535 boot up and keyboard failure
Try Safe Mode. Press F8 key during bootup and you will be presented with a black screen with multiple choices. Select "Safe Mode". This will load Windows with minimal drivers and with admin login option. If you can log in as administrator then create a new account in the Control Panel. Restart the computer and shut down. If it shuts down correctly then you are half way there, windows OS is not to badly corrupted. Boot up and if it comes up normally select the new profile you created.
If this does not work, then you will have to repair the system files, for which you will need a OS CD or restore disk.
Nov 09, 2009 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Will not boot
Insert your bootable OS software disc in the CD/DVD drive and boot from the ROM. Run checkdisk and then try to repair the OS from the original OS disc, it should give you a chance to start the PC after that continue as per instructions on the screen...................sodeep
May 11, 2009 | Dell Inspiron 530 Desktop Computer
Ntldr missing error
Ntldr is the Operating System bootup file. To boot into Windows, Ntldr file is must..
IF you have the Operating System disk with you, do the OS repair. This will resolve your problem...............
Sometimes, OS disk might be problematic, in such cases, you need to go with another disk to reload the Operating System.
Jun 21, 2008 | Dell Microsoft Windows XP Home Edition
Gateway MX6442 Notebook Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
