Question about Toshiba Tecra T9000 Notebook
Motherboard defective i have a toshiba laptop.motherboard is defective.can it be replaced with a new one/can i repair it?
    Sergeant:
    Champion:
  • 310 Answers
Are you sure its the mother board? if it is its probably a cold soder joint . replace it theres not enough time to repair it
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Dec 30, 2007
Toshiba satellite pro l450d charging problems
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue
(http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
Nov 24, 2012 | Toshiba Computers & Internet
MY TOSHIBA SATELLITE L305D -S5938 WONT TURN ON
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
Oct 29, 2012 | Toshiba Satellite L305D-S5938 Laptop
My Toshiba Satellite A505 laptop won't stay on. The tray at the bottom says "No Battery detected" and the computer shuts off after about 5 minutes, even when plugged in. It also won't connect to my...
Take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 29, 2010 | Toshiba Satellite A505-S6975 Notebook
I HAVE BEEN TOLD THE MOTHERBOARD HAS COME UNSODDERED FROM "SOMETHING". I HAVE TO HOLD THE POWER JACK AT A CERTAIN ANGLE TO BE ABLE TO START THE LAPTOP UP, THEN IT WILL SHUT DOWN AFTER 10 SECONDS. CAN...
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 15, 2010 | Toshiba Satellite A75-S211 Notebook
My Toshiba Satellite's motherboard needs replacement. The Laptop is only one-and-a-half years old. Can it be replaced with a used motherboard, without having to go buy a new one?
You will have to contact Toshiba's support for that. You can check your warranty here, and if it's ok, they should be able to repair it for you. Otherwise, manufacturers make their own custom motherboards, so it's highly unlikely you'll be able to replace it on your own.
Jul 28, 2010 | Toshiba Satellite L305-S5908 Notebook
Toshiba LED Power light flashing 1 blue and 2 orange
Remove the ram and re-install. If still fail, ur RAM is defective or has error.
Apr 03, 2010 | Toshiba Satellite A200-0ET00X Notebook
No display / defective motherboard
this some shortage only in the motherboard can repair this.... in toshiba problem lik this. the power button in on. but the cpu fan and the processor not work, of course no display....you to need to chang some part in the motherboard. ..... try to bring in laptop expert..
no chose my dear becase you lost the warranty....
May 29, 2009 | Acer Computers & Internet
Toshiba P105-S6004 Laptop will not charge battery
Motherboard repairs are often poorly done and they are expensive except for the simplest jobs like replacing the DC jack. And new motherboards are also generally very expensive. And cheap way out of this is buying a used battery charger or a used working motherboard. eBay is usually the best place to start. Good luck!
Jan 30, 2009 | Toshiba Satellite P105-S6104 Notebook
Computer shuts off
Use can air and shoot it thru the vents.
Nov 12, 2007 | Toshiba Satellite A75-S226 Notebook
Problem with Motherboard
I had the same problem. I took it to my nearest toshiba repair center, turned out the hard disk was defective/corrupt, the tech repair guy replaced it and it worked inmediately. Good Luck.
Nov 07, 2007 | Toshiba Satellite P205-S6287 Notebook PC
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
