Question about Casio Exilim EX-S600 Digital Camera
Camera resets when powered off
My camera goes to the initial setup screen (language, location, date & time) whenever it is turned on - default date is 1.1.05. How do I replace the internal CMOS battery? How much does it cost?
  • 1 more comment
  • zando222 Apr 13, 2008
    I have the same problem with my Casio EX S600.
    The camera does not save others setting either. I have even reformatted the memory.
    Casio has not information about this problem in the troubleshooting section of the manual
    It is very frustrating to have to set all settings every time I turn the camera on.
    Solution 1 does not help
  • stazza Jul 14, 2008
    I have the same problem too and I haven't had my camera for very long. It's very irritating to have to reset it all the time when I want to take a pic. I've tried leaving it to charge and resetting it but nothing works
  • gabrielfr Dec 28, 2008
    Did any of the guys above fix the problem?
    I can't get rid of the initial setup screen every time I turn on mine.
    I bought it yesterday, I guess I will just swap it.
    The manual dos not have a troubleshooting section for this problem.
On my mother-in-law's Exilim camera, we resolved the issue by formatting the camera's internal memory storage (take out your memory card and navigate to the format option on the menu). You'll need to then set the date and time again but it then seems to store it. Hoping that helps someone.
Posted on Dec 26, 2009
I have the same problem too, i think i pointed where the cmos battery is but i am not sure if it is the battery or not. when u open the door it should be to the right. it is not accessible til you open the camera. again im not sure if that is the battery. once i comfirmed. ill buy a broken one on ebay and swap it out.
Posted on Jul 24, 2008
    Problem Solver:
  • 5 Answers
YOU MAY LOOK THE SETTING FOR THE ADJUSTMENT OF THE DATE SETTING , SCAN YOUR MANUAL BOOK AND THERES A GUIDE FOR YOU PROBLEM
Posted on Jan 15, 2008
On the screen shows turn off and then turn on again and again-it does not turns on any way
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa.
Jan 17, 2011 | Sony Cyber-Shot DSC-W7 Digital Camera
Configuring display language, Date and Time Settings.
Perform the reset operation to initialize the camera’s setup (page 136). After that, configure each setting. If the language selection screen does not re-appear when you turn the camera on, it means that the camera’s built-in memory management area has been restored. If the same message appears after you turn power back on, contact your retailer or a CASIO service center.
Main support number800-962-2746
http://www.fixya.com/support/p504372-casio_exilim_ex_z1000_digital_camera/manual-19919
Jan 29, 2008 | Casio EXILIM EX-Z1000 Digital Camera
How do I change the incorrect language I selected - the screen was so sensitive and responded to a brush with my finger. Now I can't read the words of a language I don?t even know I chose, to see an...
For the Coolpix S4000: Tap MENU. Select the wrench icon for the Setup menu. Select the open book icon for Language. Pick the language of your choice.
Jan 01, 2011 | Cameras
How can I reset the camera or modify the date & time of it? Regards
Initial settings
Y
our camera's display language, date and time
should be set before taking photos or videos.
To set the date and time:
1 Turn the power on. Press the Menu button to
enter the camera's settings menu.
2 Press to select the Setup tab.
3 Press to select Simple Mode, then OK/DISP
to open the Simple Mode submenu. Set Simple
Mode to Off.
4 Press to select Date & Time, then press
OK/DISP to set the date and time.
5 Press , , , or to adjust the date and time.
When you are done, press OK/DISP.
Dec 14, 2010 | Insignia NSDSC10A Digital Camera
Won't zoom :(
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
1. Please press the Menu button on the Camera.
2. Then, select the SETUP menu and select the SETUP 1 option of the Camera.
3. Then, select the Initialize option to OK.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists then Service may requires to resolve it.
Aug 11, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Problem with flash and a blinking message
I have also a DSC-W30 and I tried to basically reset to the default settings, going to Menu button, (Right Arrow), Setup, Down Arrow (2 times),Select with round button,Scroll down to Initialize and select OK.
You must inizializate your camera, but dont leave time adjusting the date. When your camera restart select any date quickly, then change the camera to the ISO option, to desactivate the flash temporarily, then change to AUTO option, and desactivate the flash. For the moment is the best option. Te problem may be ocasionated because your camera was in wet area and ocasionate a shortcut, but you need to verify if the problem is in the flash card, in any terminal, or in the motherboard.
Oct 21, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Date & Time loss with Exilim EX-S600
Good Morning :
Hope that you are wellJ
This is the response from Casio:
"The date and time will reset and the setting will need to be readjusted. The camera does not have a separate battery for the clock. The date and time will reset whenever the camera is not supplied power by the battery and USB cradle for about 24 hours."
Sounds a bit messy to me.
If I can be of further assistance, please let me know.
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful morning.
Sep 30, 2008 | Casio Exilim EX-S600 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
523 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
