Question about Network Storage Systems
Fastora nas-208 cannot reset network attached server. it will not automatically assign itself an ip addr as it did in the past. I cannot find manual or software on the web. any ideas?
  • 3 Answers
SOURCE: Can't assign ip configuration to NAS 208
Run Fastora Assist, it should detect your NAS even if no IP address is assigned to the NIC(s). Make sure to connect all NIC(s).
Posted on Jan 10, 2008
0 characters
1 Points
I had to replace my router and I now cannot see the dlink enclosure. I wanted to get the IP so I can reconfigure the IP address but like I said I cannot seem to get the device to show up on my belkin...
You can try a couple of things, easy thing is to reset the NAS server by unplugging it and allowing it release its leased IP address, assuming that it is setup for DHCP. Once this is reset it should grab another IP address. If you remenber setting it up for a static IP, then you could do a google search for an IP scanner or find one that you are comfortable with download and install look for device on your network that will give you your IP to the NAS server. Good luck
Nov 28, 2010 | D-Link DNS-321 Network Attached Storage...
I picked up a Fastora NAS-T4, but the previous owner no longer recalls the root password on the device. Is there anyway to reset the device to factory defaults? I see no 'reset' buttons available on it.
Turn off the NAS.
Press AND HOLD power button for about 30 secs.
That will force a hard reset and reset the unit to factory defaults. You will lose all data on drives that are plugged in at the moment. If they are in an ejected state, it may save your data, but I have not tried that.
Oct 15, 2010 | Fastora NAS-T4 Hard Drive Array
My Black Armor NAS keep changing its IP address and can't be accessed most of the time on the network. Hw can i fix this
Configure your network's DHCP-server to *ALWAYS* give the *SAME* IP-address to the NAS -- use the (unique) MAC-address of the NAS's network-adapter to assign a "static" or "fixed" IP-address to the NAS.
Jul 27, 2010 | Network Storage Systems
Fastora NAS-104WR
It all depends on how mission critical this NVR is, (and how much money you have to spend)
A good rule of thumb is the more redundancy the better, so in theory, if you have the money, you should buy the second NVR, however if you cant afford an entire second unit, you should look at doing hard drive backups of that unit.
If you have any more question, please let me know!
May 17, 2010 | Fastora NAS-104 (nas-104d) 0.25 GB Hard...
Smcnas04 is down, how to take the files inside
We have this product but can not be used for requesting a serial number. and we lose the serial number. thanks for help
Apr 09, 2009 | SMC Networks TigerStore SMB NAS Storage...
Reading T4 Device
Did you try to boot the system without all the harddisks inside (keep at least one).
This helped me to bring up the NAS-T4 up again.
Mar 04, 2008 | Fastora NAS-T4 Hard Drive Array
Probably the NAS got the same IP address of the router/switch. Something like Try changing your router default IP address to Look for the NAS now.
Dec 22, 2007 | Network Storage Systems
My Nas Fastora T4
There's a 9-pin serial connection on the back, can you use that connection to a terminal to see anything? Also, if you don't have access to the manual, visit this link to download the manuals:
Oct 22, 2006 | Fastora NAS-T4 Hard Drive Array
Reset root password
see for an answer
Nov 04, 2006 | Fastora NAS-104 (nas-104d) 0.25 GB Hard...
Network Storage Systems Logo
Top Network Storage Systems Experts
Daily Mehdi
Daily Mehdi
Are you a Network Storage System Expert? Answer questions, earn points and help others
