My new Sony VAIO has the Poineer DVR k17 and the dvd driver has just stopped reading my cds/dvds - DVD is not even shown on my computer! quote from device. Any ideas please
Comments:
Dec 29, 2007
- Found the solution try this -bit scary but it woorked for me!
1. Choose Start > Run. 2. Type regedit in the Open text box and click OK. 3. In the Registry Editor dialog box, navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder. 4. Select File > Export (Windows XP) or Registry > Export Registry File (Windows 2000). 5. In the Export Registry File dialog box, select Selected Branch under Export Range, name the file (for example, CDDVDkey.reg), and click Save to save the file to the Desktop. 6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box. 7. Select the UpperFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box. 8. Close the Registry Editor. 9. Restart Windows.
I got the same problem. I've read so many thread before and no one have any answer to that situation.
I'm using Windows Vista and my pc is a Sony Vaio VGN-FZ21E ...
The situation is this one : In first time my CD/DVD writter desapere. I think it's linked to my last utilisation of TuneUp utilities (I tried to change the icon of the dvd writter .. :D). So I directly look to my "gestionnaire des périphériques" (sorry I'm using french version of vista) to see if my device were correctly installed and I saw that it were a yellow /!\ (I don't know the name ..) next to the icon. So I checked the proprity and the driver were not correctly installed : error code 10. So after looking solution on google, I found something who told to install the pilote of windows but I doesn't work. In fact after installation and restarting my pc, the DVD writter weren't able to open any cd .. So I uninstall the driver and I reinstall with the windows assitant for installing driver. But it couldn't intalled correctly the new driver ! (error code : 1).
Vista vista ... : /
Thanks for your help ! and sorry for my english :D Franck-   Guest
Hello olejonok, I ran into this problem while helping a friend with her laptop. Here is the solution:
1) Visit the following webpage: http://esupport.sony.com/perl/swu-download.pl?template=EN&mdl=&upd_id=2031&SMB=YES
2) Download "SOOOTH-01106200-US.EXE" 3) Run the program and follow the instructions, then reboot. There are several registry filters which, when removed and the system rebooted, re-enable your drive. Applies to: DVR-K17 VGN-CR220E PCG-5J2L
screen is dull while on ac power. When running on battery screen brightens up but battery does not...
(More)
screen is dull while on ac power. When running on battery screen brightens up but battery does not last long. Power supply is supplying 19.17 volts which but on the power supply is written 18.5 volts.
