Question about Sanyo VWM-950 VHS VCR
Audio works but no picture
This is the second Sanyo vcr that I've had and it's done the exact same thing. When I try to play a vhs tape, there is no picture, just "snow". I have audio. If I fast forward the tape, I can see the picture clearly but it's fast forwarding. It does the same thing with the head cleaner tape also. Any ideas of how to fix it without too much expense or buying a new one?
Thanks.
    Problem Solver:
  • 5 Answers
Simple clean head with Q tips by hand use the head cleaner on Qtips clean good dont brack the tip on head .good luk
Posted on Dec 27, 2007
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
PAL VHS bought from England won't play in my (USA) Sanyo VCR
Short answer is no,if it was a dvd you could,but not tape...sorry
May 03, 2009 | Televison & Video
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr.
3.press play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
VHS Tape on Sanyo Doesn't play on other VCR's
the heads on the sanyo vcr may slightly be out of alignment from years of use.when playing a recorded tape from this vcr to another, the other vcr's alignment maybe right on track thus causing the poor quality.you can possibly try cleaning the heads with a head cleaner or a high grade blank tape,but i don't think this will solve the problem. but you can try.
good luck
wg
p.s also try higher quality tapes to record on.
Feb 04, 2008 | Sanyo VWM-900 VHS VCR
SANYO VCR VWM-900 playback is jerky
Your post/description indicates that possibly the brake mechanism of the supply reel is acting up. A typical VCR has 2 reels inside that spins the tape. The left side is the supply while the right is the take up. If the brake (on the left/supply) is engaged (even partially), then the entire mechanism would have a hard time pulling the tape around the video/audio head and would partially be stretching. This would represent itself as jerky audio/video in most instances. There would possible also be a low screeching sound coming from the machine/tape. An indicator would be stretched tape - there would be uneven edges of the tape.
Since this is an electro-mechanical problem, perhaps your best course of action is to seek the services of a qualified video machine technician.
Alternately, it may be possible to loosen things up by first fast forwarding the entire tape and thereafter rewinding fully before you play it.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Sanyo VWM-900 VHS VCR
How do you copy from one vcr to another
ok hear u go
recorder vcr all rc pin go in vidio in audio in .
play back vcr all pin goes out audio out vidio out ..
blank tape gos to recorder
hope that help u
Nov 30, 2007 | Sanyo VWM-950 VHS VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sanyo VWM-950 VHS VCR Logo
191 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
