Question about Braun M880 MultiMix Hand Mixer
The switch is broken
The mixer switch will only work on high (level 3). I have checked the internet and this seems to be a relatively common problem. However, I have not been able to find a solution. Do you have any ideas?
  • wf1992 May 05, 2008
    Same problem. On my second mixer. Love it while it works, but if I can't fix it, I don't think I'll be dumb enough to give Braun more $$ to buy a third! Now how the heck do I open this thing??
Mine did the same thing. I found the ball bearing inside the switch had fallen off. Put it back on and it works like new!
Pull the mixer case apart. Push in on the seam in the front and back and it will pop open after you remove the 1 screw. Pull the switch apart. There is a spring inside the top part of the switch and a small (1/8") ball bearing should be on top of the spring. Chances are, it has fallen off. Find it and stick it back on the spring while holding the top part of the switch upside down. Put the mixer back together.
Posted on Aug 03, 2008
  • John Doe Nov 19, 2012
    When I popped mine off, a rubber gasket was loose so when I wedged it back in between the housing and the circuit board of the switch, and put it back together, it ran on all three speeds again! Calling Brauns number got me no whereas they do not make the mixers or any parts and all I got was the dumb reply off the script from a P&G call center, somewhere in the Pacific so much for P&G being helpful or understanding that some items don't break. Then again, I bought Mr. Clean products that they no longer sell refills for either,
    Problem Solver:
  • 5 Answers
I just fixed mine. My daughter dropped it (again) and speeds 2 and 3 failed to work so I disassembled it and found a broken center terminal on the power transistor. I saw a fine crack so I soldered it. I also added much needed strain relief to the heat sink. It works fine now. This is a poor design. The power device has a heat sink attached and there is no strain relief so the transistor can move back and forth at least 3/8". For a tool that sees a lot of vibration and shock, this heat sink should be tie strapped or have hot melt glue to prevent movement. Gary
Posted on Dec 31, 2008
  • Eric Krueger
    Eric Krueger Nov 11, 2013
    Nice catch on the broken IC leg, Gary. I wouldn't have found it without your post. Eric
What you said was true but it didn't solve the problem. Switch must be bad also.
Posted on Aug 06, 2008
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchen Aid Mixer won't start - grease leaked out from ring
The leaking grease has very little to do with it not going, remove the chrome drip ring (yes it's called a drip ring, it is used to catch most of the drips) and clean it out & wipe around the planetary. The oil is separating out of the food grade grease due to age or lack of use or both. Remove & check the carbon brushes under the side caps on the motor. They are keyed so will only work when installed the correct way. You may find the brushes worn out and in need of replacement. Observe which way they come out, one corner is ground off and that is the key. If that is not the problem then you will need to look under the back cover, sometimes there can be a broken or loose wire there.
Nov 13, 2014 | KitchenAid K45SS Classic Stand Mixer
Mixer wont start
Check for broken wire under back cover. Check operation of switch contacts on black speed control plate. Check carbon brushed under black screw caps on the sides. The brushes are keyed, they only work one way.
Jan 08, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Older, (1950) Hobart A-200 runs in first gear no matter where the shifter is set?
My Hobart had a switch on the side to change Gears... 3 Different Speeds
Apr 11, 2013 | Hobart Food Mixers
Power switch turns on by itself
Bring the mixer to a place that services these appliances. They will have to replace the switch. This is common on appliances.
Jerry G.
Nov 25, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My mixer will only run on high speed. The other two speeds (low & med.) do not function
check the warranty? it may be still covered, sounds like a replacment switch/unit required.
Aug 16, 2009 | Braun Food Mixers
My kenwood mixer will not mix, the liquidiser works ok but the mixer rotates very slowly.
Hi, maybe you have 3 problems:
1 the tooth belt its nearly broken.
2 Problem in some gears
3 If its model A701/A check the back cover, and the pin in the top. its in good condition
regards
Kenwood Chef Restore
Jul 02, 2008 | Kenwood KM300 Chef Stand Mixer
Oil coming out of mixer above bowl
Don't open up the "works" part of your mixer if it is still under warranty!!!! If the policy hasn't changed, you'll void the warranty by doing that.
KitchenAid has one of the best user forums of any company as far as I'm concerned. The participants are great and the monitors are exceptional (some of the best problem solvers you are likely to run across). You may find your experience already has a thread, if not, post it. I checked in and they seem to have added a video library that has some of the topics I've seen posted at this site. Tell them "mnme" sent you. (LOL)
http://www.kitchenaidconversations.com/
Nov 11, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Braun M880 MultiMix Hand Mixer Logo
798 people viewed this question
Top Braun Food Mixers Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Are you a Braun Food Mixer Expert? Answer questions, earn points and help others
