HP vs15  15 in. Flat Panel LCD Monitor
Problem for HP vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor
Help
By cakturner on Oct 12, 2009
help my monitor is all messed up, and we didn't do anything
we, just turned our computer on yesterday and there are lines and it is fuxxy
Best Solution
posted on Oct 12, 2009
Very Helpful)
ejeetnet
Rank: Wiz
Rating: 81%, 38 votes
Seems like the resolution is set in correctly, try lowering it in your operating system
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
firesnake09
Rank: Wiz  HP Expert
Rating: 84%, 389 votes
Try to power cycle first the monitor. Turn the computer off and disconnect the monitor. Leave it disconnected for about 15-20 minutes. Then reconnect it to the computer and turn the computer back on. If same problem occurs, try connecting the monitor into another computer to see if it's the monitor or the computer.
The best thing to isolate the problem is if you are connecting the monitor using DVI, try connecting it to the computer using VGA connection. This will tell you if the problem is the monitor or the connection to the computer.
If the problem disappears using VGA connection, then it's not your monitor but it could be the DVI connection in your computer.
Have a great day!
Was this helpful?
Yes
No
Popular Solutions for HP vs15 15 in. Flat Panel LCD
Questions and Unsolved Problems for HP vs15 15 in. Flat Panel LCD
Do you recommend HP vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor?
Answer
Answer
turn if on picture shows and immediately goes black. turn monitor off and then on again. picture... (More)
Answer
HP 15" LCD monitor model PE1233 - powers on then off then on then off etc. Is it the... (More)
Answer
I want to know how I can hook The HP vs 15 LCD monitor to my mac G5. The connections don't match up.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitors Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
