Question about Sony CDX-SW200 AM/FM Compact Disc PlayerCDX-SW200
Sony compact disc player initializing
The Sony unit was unplugged, stored for 4 days in another room, and when returned to original location, the CD player is constantly initializing. Radio and tape player seem to function, but CD player only initializes for hours.
  • 3 Answers
Have you tried pressing hte RESET switch?? It's behind the removeable front of the stereo, use a biro or something and hold it in for a bit.
Failing that, check that there isn't a CD already in it, could be a dodgy CD?
Posted on Jan 26, 2009
Hi i have the samsung ht q20 dvd cinema system, i recently put a code in the dvd to make it multi region however now it does not play any original or copy dvds at all... i read in a forum you can revert...
While "NO DISC" message appears on the display of main unit, hold the main unit's STOP button for longer than 5 seconds. "INITIALIZE" appears on the display and all settings will return to the default values.
Using the RESET function will erase all stored settings.
Aug 05, 2011 | Samsung HT-Q20 Theater System
DVD Player is not reading DVDs. when switched on NO DISC prompt appears.
It could be cause by a dirty optical lens. You can try cleaning it by using commercially available CD OPTICAL LENS CLEANER. Just follow the instructions given by the manufacturer. If nothing happen and if still under warranty just bring it back to the store or to the authorized service center. If not try to follow this simple step before you call a local repairman. Sometimes a dirty optical lens cannot clean by a commercially available optical lens cleaner. (1) Unplug the unit from the wall socket. (2) Unscrew the unit to remove the protected cover.. (3) The optical lens is located in the middle section of the CD tray assembly. here is the picture. Never touch the optical lens because it may add more add more damage on the unit. (4) use a cotton buds and a drop of cleaning solution or a drop of water if you don't have... Clean the optical lens but do not push so hard, just enough touch... After you finish cleaning the lens just return the protected cover from its original position... then plug the unit again to the wall socket and try if the problem is solve... Tyhomearceo_0.jpg homearceo.jpg
Jun 28, 2011 | LG Televison & Video
We are not able ti play All the time it desplay LOADING but it doesn't open
Sometimes a dirty optical lens is the cause of the problem.. You can try cleaning the optical lens by using a commercially available CD OPTICAL LENS CLEANER. If the unit is under warranty just return the unit from the store or in the authorized service center. If not, follow this simple steps try if this solution may fix the problem before you call a local repairman.. (1) unplug the unit from the wall socket. (2) unscrew to remove the protected cover. (3) A drop of water on the cotton buds. Do not use benzene, thinner or other volatile chemicals. Also do not use record spray or antistatic agent. wipe off the dirt on the optical lens. Once finished, just return the cover from it original position. And then plug the unit and try if the problem is solve.... Tyhomearceo_3.jpghomearceo_2.jpg
Jun 28, 2011 | Pioneer DV-220V-K DVD Player
Lost code for sony cdx-m800
You can enter a 4-digit security code as an option after purchase of the unit. If you do so, make sure it is noted down somewhere. If you did select a code (or the previous owner has done so) this must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational. If the code is lost or forgotten I am afraid the unit has to be re-coded by a Sony dealer.
Hope this helps, Good luck with it.
Apr 02, 2011 | Sony CDX-M800 CD Player
Como resetar o gfx8
zoom GFX-8:
The All Initialize/Factory Recall function is a special function
that lets you reset the GFX-8 to the condition in which it was originally shipped. When All Initialize is performed, all settings of the unit including all user group patches are returned to the default condition. Factory Recall can be used to reset only specific user group patches group to the default settings.
1. Turn power to the GFX-8 on while keeping the STORE key depressed.The display shows "ALL-INIT".
• To perform All Initialize, Continue with the next step.
• To perform Factory Recall, Use the BANK UP/DOWN foot switch and foot switches 1 - 4 to select the patch (from a user group) that you want to return to the factory default condition.
2. Press the STORE key once more.
All Initialize or Factory Recall is carried out.
If All Initialize was carried out,
the unit automatically returns to the play mode.
Note that when All Initialize is executed,
the contents of all patches stored by the user will be overwritten (erased).
When wishing to cancel All Initialize/Factory Recall,
press the EDIT/CANCEL key before step 2.
source: ZOOM GFX-8 User Manual.
Oct 13, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
TEAC-P1260 - Initially Cd would play then eject randomly. Next would play only a few seconds then eject. Now has eaten a disc and will not eject. Any suggestions?
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricalshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you; Regards; VOTIT
Jun 08, 2009 | Teac CD-P1260 CD Player
Cdp-xe270 no RCA jacks
Thanks for update, You pressed right button so having solution :)
Below is an exploded view of required part at rear of CD player.
Part number is as follows...
1-785-868-11 JACK, PIN 2P (ANALOG OUT)
Available in Part Store for $4
Have a nice day.
Jan 17, 2009 | Sony CDP XE270 CD Player
Curtis Micro Radio/CD Player Shelf System RCD882
When you load the CD, the CD itself sits on what is called the CD Table. The height of this table is somewhat critical to proper operation of the CD. Since this is a new unit, this should not occur. Return the unit for exchange or repair. If the unit is less than 30 days old, insist on an exchange. You should not have to be without the unit for something that new.
Dan
Mar 28, 2008 | Curtis RCD882 Shelf System
Sony cd deck receiver HCD VA550
I have the same issue. Did you get an answer ?
Mar 16, 2008 | Audio Players & Recorders
Car Audio & Video Logo
227 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
