Televison & Video Logo
Posted on Sep 29, 2017
My phillips model #32PFL5332D/37 flat screen will not come on
My phillips model #32PFL5332D/37 flat screen stopped working. the power flicker several times and the set would never come back on. the power on led will come on and a small red led comes on also, but it does not flash just stays on. neither lights will go off by remote or power switch on the tv, you have to unplug the set to get them off. can someone help?
John Brumenschenkel
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Sep 29, 2017
John Brumenschenkel
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
2029
Points
41
You have been the victim of a power surge. It will need to be repaired in order to work.
5 Related Answers
Anonymous
  • 138 Answers
  • Posted on Aug 20, 2008
SOURCE: Philips 42PF9630A/37 PLASMA TV
Replace that board the part number is 996500032643. go to www.vancebaldwin.com for the price of the board.
David Low
  • 458 Answers
  • Posted on Jul 25, 2009
SOURCE: we have a phillips model #32PFL5332D/37 it has a
Yes this TV should tune to both Digital & Analogue reception. See below I have copied an extract from the Philips technical site which gives you verification that this has digital capability. Hop this is of help to you. Next to analog NTSC broadcast reception, your TV has an integrated High
Definition TV tuner which receives, decodes and displays terrestrial ATSC and
unscrambled cable (QAM) signals.
HDTV quality is only reproduced when a broadcaster or cable provider broadcasts
HDTV signals.
CoppellTVRepair.com
  • 778 Answers
  • Posted on Nov 05, 2009
SOURCE: Hi, I have a Philips model 37PF7321d/37, 37 inch
The power board numbers you need to search for on eBay is 310432847531 or 310432838621 - they are compatible according to Philips.
Anonymous
  • Posted on Dec 12, 2009
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
Anonymous
  • Posted on Jan 02, 2010
SOURCE: Phillips Flat TV Model 20pf4121\105 (Flashing green led)
electrolitic capacitors 1000mf /10 v in pover unit
2answers
Phillips 32PFL5332D/37 I have no remote control is there an app I can download on my phone?
If you phone has an IR output yes but I am not aware of a current model that has this feature.
Philips standard RC5 controllers are very inexpensive through fleabay or amazon, even from your high street store.
Phillips TV Model 42PFL7422D/37 that has audio but no video.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=repair%20led%20tv%20screen
32" phillips tv turn self
If you go to this website, http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=32PFL5332D/37&slg=en&scy=US
You will see firmware information on the right hand side of the screen. Please open and read the Firmware Upgrade Read Me file. These contain instructions and the update history of this model TV. Underneath the Read me file you will find the download link. You must follow the instructions in the read me file or you risk damaging your unit further.
This is from the read me:
The set is switched OFF/shut down by itself after a few hours turning ON.
The newest upgrade should fix all your issues.
Hope that helps!
Phillips TV Model: 52PFL7422D/37 Purshased this TV Dec 16, 2007. No I have blank screen with the TV blinking a read light at the left - the red light flickers - blink, blink,blink,blink,blink then 3...
First place to check is the power supply board. I have not repaired this particular model. I'm very certain you have two bad capacitors in the power supply. This is a classic problem for Philips flat TVs. The capacitors will be bulged or skinned. Be sure to replace them with same values. I would certainly gamble my time removing the power supply for inspection. Spending a few bucks on two capacitors may prove good. A working TV is near. Thanks for asking and show all hands of support!
2helpful
Our Phillips 47PFL5432D/37 LCD HD TV is having a flickering problem. Looking inside the back, if I disconnect the 2-wire connector that goes from the SLAVE board to the LCD display, the flickering stops. ...
mine was doing that before the picture finally went all the way out
till then to get it to stop flickering open menu go to picture setting and cut on light sensor
its prolly the backlights going out as well has the capacitors going out
8helpful
2answers
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
2helpful
2answers
Phillips TV Model #32PFL5332D/37 Screen got broken. Replace or buy new?
Ok. Now this is a really easy decision. Buy new why? I ran a search for the cost of the part at partstore and its 588.95$ + Labor. It may go well over 700$. However all is not lost. Although the screen is damaged the other parts are good. There are stores like shopjimmy.com who will be more than happy to buy the parts(like Power supply assembly, mainboard assembly, inverter board etc.,) and you can easily get back more than 50% of the cost of the television by selling the parts. So add 300$ to that you can get a new TV! But do not disassemble it yourself if you do not have prior experience. It holds lethal voltages of about 15k-20K volts for several hours after disconnecting from the power supply. Get a service manual and read it thoroughly if you wanna do it yourself. It will show you what components to avoid.If you had the set unplugged for more than a couple of days then it should be relatively safe.
Sai.
1helpful
2answers
We have a phillips model #32PFL5332D/37 it has a flat screen. Is it digital or analog
HDTV signals.
Blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Philips LCD Won't Power On
Download driver upgrade from www.philips.com/usasupport
Save file onto usb drive
Insert usb drive into TV, left side near back
Power on TV
See website for release notes. The patch fixes a bunch of issues
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
