Question about AOpen (60NJW37004) CD-RW/DVD-ROM (Combo) Burner
Help!!!! I need a CDRW module for Aopen 1846 openbook
I can NOT FIND a CDRW or CDRW/DVD drive for my Aopen 1846 notebook PLEASE !! CAN ANYONE help me???
    Genius:
  • 1,665 Answers
I think there are in stock 3 items Item No : MG433319 Price : $103.55
try this
http://www.gsbs.biz/gsbs/details.asp?item=MG433319
Posted on Dec 26, 2007
My screen shows '' internal hard drive not detected,to resolve this issue try to reseat drive '' can someone help please. thx
This could be an issue with a bad drive or a bad drive controller on the mother board. If you have access to another drive try swapping it out otherwise you will need to take it to a shop and have it tested. You can also see if you have the disk that came with the machine it may have a diagnostic program on it as well.
Jul 30, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Need help finding the driver for free
GOTO > http://download.aopen.com.tw/Default.aspx
Click on advanced search.
In the keyword box type 1608
Click on search.
Your driver should be there.
4th box down?
May 04, 2009 | Televison & Video
Driver problem with DVD/CDRW device driver
Hi sandystell,
Well normally in Windows XP the DVD/CDRW drive won't need anymore drivers, since Windows automatically installs one for it. I assume the problem you're having is that the drive is not able to read CDs/DVDs or burn a disc, correct?
If that is the case you can actually follow this microsoft KB article: http://support.microsoft.com/default.aspx?scid=kb%3Ben-us%3B314060
This will give you indepth help on what to do. I would recommend that you do the removal of the upper filters and lower filters in the registry.
You can test if the optical drive works in Safe Mode, by pressing F8 on startup and choosing Safe Mode, then logging into yourr account. See if the disc is read in Safe Mode, if it does, then you have a program that is conflicting with the drive. I would recommend that you run MSCONFIG, goto Startup tab and disable most if not all of the startup items, then click on APPLY then OK.
The next thing is running the diagnostics for the computer to see if there any reported hardware problems. Now if all tests passed, the next step is reseating the optical drive (if possible) check the computer manual on how to do procedure, otherwise you may have to call up Dell Technical Support.
Now you may have to replace the drive itself since it could be defective now.
Hope this helps!
Peace! :)
Oct 20, 2008 | Philips DVDRW 228 DVD+RW Burner
Dvd cd combo not working
You can download firmware, drivers, instructions etc. for your combo from here: http://download.aopen.com.tw/Default.aspx
Just select your product, model and download what you need. Make sure to allow your firewall the ftp access to these files.
Apr 27, 2008 | AOpen (com5232) CD-RW/DVD-ROM (Combo)...
T23 notebook
Yes no problem.
Sure they made DVD writers for those - usually about $80-100.
If you just want a CD burner and DVD player they are only $40-$60.
You can easily eject the drive by hitting the release lever to the right of the CD drive.
The CDRW/DVD combo part numbers are 08K9820 22P6980 08K9818 or 13N6765
They have cdrw/dvd combos for $34 at compuvest.com brand new. I saw DVDrw drives for $70 on ebay -look for part numbers 08k9868, 08K9694, 08K9572, 08K9818, 08K9820, 08K9867, 22P9109, 22P7011, 22P6991, 08k9785, 27L4358, 08k9784, 27L4359
Dec 21, 2007 | IBM ThinkPad T21 Notebook
AOpen DUW1608/ARR - DVD Problem
it's a classic drive failure problem where the laser can no longer burn or read dvd's, and show rhr writer as a cdrw, but may still be able to read or write cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | AOpen DUW1608/ARR (914ID37204) Burner
How to install an apoen 5224 crw
If you have only a hard drive apart from this CDRW look at the connection to the hard drive and follow to the IDE0 connecter on the mobo.(do not connect CDRW to this as it will slow up the harddrive). Next to this will be another connector IDE1, if you already have a device connected to this there will be an IDE cable already there. On the IDE cable half way up will be another connector, connect this to your CDRW and set the plastic cap jumper to the SLAVE position. If no device connected you need an ide cable from the connector on the motherboard to the CDRW and set the jumper at the back at slave. Just remember if you have two peices of hardware on one cable one is set at 'MASTER' and one is set at 'SLAVE'. Don't forget to connect the power lead from the power supply unit to CDRW. Restart pc and it will be auto detected.
Jan 31, 2007 | AOpen (91.3FD37.474) CD-RW Burner
AOpen (60NJW37004) CD-RW/DVD-ROM (Combo) Burner Logo
79 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
