Question about Bushnell NorthStar 78-8831 (525 x 76mm) Telescope
78-8831 Just got a 78-8831 and set it up according to instructions. After inserting lens into eyepiece, I can't see anything at all. Dont worry, I've removed the front cap from the the main telescope. Something leads to believe I'm either missing something real fundamental or my telescope is broken. Please help
  • 6 more comments
  • monznjo Dec 28, 2007
    We set it up to the instructions also, but the tube doesn't seem to have enough light. I looked for obstructions, couldn't find any. I can't even see things in the daylight. What am I missing? Can't wait to look at the stars,
    Happy New Year!
  • rnska2 Jan 06, 2008
    I don't have a solution. I have the same problem. I can't see a thing even taking the end off. What should I do now.
  • dkjf Jan 07, 2008
    we have set our telescope up correctly but we cant see anything - please help
  • rureye Feb 21, 2008
    Just got a 40-076420H and set it up according to instructions. After inserting lens into eyepiece, I can't see anything at all. Dont worry, I've removed the front cap from the the main telescope.
    Tasco Luminova
  • Anonymous Mar 27, 2008
    just got a new telescope and set it up but can't see anything. I have removed the covers so that is not the problem
  • cat9554 May 08, 2008
    My telescope doesnt work at all, everything is black when i look throught it.
  • Anonymous Jun 10, 2008
    Have a new Bushnell model 78-9003. Set it up exactly as the instructions indicate but can't see anything. What's wrong?
  • jaydayray Jul 15, 2008
    cant see out of my telestar d=130mm f=1020mm, used to work fine, could i have bumped it? always used caution when transporting? Is that something i can fix myself?
There is a mirror that can be moved to use the top or back eyepiece.
The lever is at the back on the left
Posted on Aug 11, 2008
Posted on Apr 13, 2008
    Problem Solver:
  • 8 Answers
If you dont have any experience with telescopes, I suggest trying it first in daytime, since daytime objects are much better for getting experience. Also, start with the lowest power eyepiece, the one with the largest lens. Start by looking towards something pretty big, like a car or a house, and it needs to be some distance away to even have a chance to get a focus. If your target is closer than about 1/4 mile, you should add the right angle eyepiece attachment to allow you to focus in on closer objects.
When you are finally set up with the low power eyepiece, and have a good big target in the daytime, start looking thru the telescope while turning the knob thru the entire range. At some point of knob turning, you should see some image appear in the eyepiece..Turn the knob slowly to focus it clearly.
And this is for the shaky tripod. If you can hang a book under the middle of the tripod, the added weight will help stabilize the telescope, and you should be able to see a little better, without so much motion at the slightest touch.
After you look at the first car or house, you can see how careful you have to be to use the telescope, and you can start to look at other objects. When you move to the higher power eyepieces, it will be even more critical in getting it both aimed and focused. If its off by just a few degrees, you wont see what you are looking for.
When you start nightime viewing, start with the largest object in the sky, the moon. Its the same process as daytime, except the eyepiece mechanism will have to be adjusted a little closer to the main body of the telescope.
Viewing planets and stars will be the ultimate test. Stars and planets are harder to see, since they are small, and hard to see unless they are in focus. When you can see those views, you have passed the telescope test. Its a matter of careful aim, and having the telescope focus set close to the point where you can see objects that are VERY FAR AWAY. If you are able to focus on the moon, you will be fairly close to being able to focus on the planets. The hardest part is actually getting the planet in the view of the telescope, in other words, aiming it.
The last item that can really mess up the view is a fogged up lens. Usually this happens in the summer when the scope has been in the air-conditioned room, and then it fogs up when taken outside. The solution for this is to let the telescope sit outside for 20 minutes, so the fogged lenses can clear. By the way, the same fogging may happen when you bring the telescope inside during the winter.
I hope this helps you eventually get a clear view of some amazing views in the sky. Your final exam is to take a look at the moon, the rings of Saturn, and the moons of Jupiter, some time in the near future. Have Fun!
Posted on Dec 26, 2007
I have a Bushnell Voyager telescope and can't see anything thru it at night!
Did you set it up according to the provided instructions?
Do you have a low power eyepiece inserted at the viewing end?
Have you aimed the telescope at the moon as a basic test of
If your telescope is not properly aimed at the target (a star or a planet, or other object in the night sky) then you will see nothing.
If the power of your eyepiece is too large and your telescope aim is
not "dead on", then you will see nothing.
Have you tried using the scope in the daytime? Do you see anything?
Aim at a specific object, or section of an object, like the top of a lamp-post about a block or two away, and see if you can focus on
it the eyepiece.
You really need someone at your side who has experience in using
astronomical telescopes. That would be the quickest way to solve
any problems you have.
Unless your question is very specific, and unless you provide as
much detail as possible about your problem, it will be difficult for
anyone to provide you with speecific answers that will help you
solve your problem.
May 06, 2014 | Bushnell 789961 Voyager Sky Tour 700mm X...
Cannot see anything.
do you see only black image when you look trough it?
Jan 09, 2008 | Bushnell NorthStar 78-8831 (525 x 76mm)...
When I use a Barlow lens do I insert it before focusing on an object through the eyepiece or do I insert the lens after I've focused on an object (eg: Jupiter)
You will have to refocus after inserting the barlow. The barlow will change the focal point of the eyepiece
Apr 06, 2013 | Optics
I was given a barska 40070 i was assembling it then i came across the barlow lens i tried putting it on my telescope i did but then i went outside i had aligned everything prior to it I looke into the...
A barlow doubles the magnification of the eyepiece and halves the field of view so it it very hard to center an object. Use the lowest power eyepiece (highest number) first. Center the object in the eyepiece, then you can insert the barlow between the scope and the eyepiece. You will be surprised how far off from center you are.
Dec 27, 2012 | Barska 40070 Starwatcher Compact Refractor...
Hello, I have a celestron c9,25. I adjust a nikon D3100 with T-Ring and Adapter to my telescope. Firstly I focus to moon, using an eyepiece, then I removed the eyepiece and adjusted the Nikon. The...
Because the camera has a different focus point from the eyepiece. TURN the focus knob until the camera comes into focus. OR you can buy a "focus ring" for the eyepiece which attaches to the barrel of the eyepiece and is adjustable-- then focus with the camera FIRST and then insert the eyepiece with the ring on it and lift it UP until the image comes to focus-- then tighten the ring. NOW you can use that eyepiece to roughly focus the camera.
Jun 25, 2011 | Celestron C9.25-CF 2350mm f/10 Aluminum...
The diopter setting eyepiece has come out of the body of my Bushnell 10X42 ''Waterproof'' binoculars, model 13-2410. I see keyways inside, but cannot screw it back in more than about 1/4 turn, which is...
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Apr 10, 2010 | Bushnell Waterproof Binoculars
I dont know how to use my barlow lens
I use a barlow lens quite a bit with my telescope. It is usually inserted before the diagonal if you use one or before the eyepiece if you don't. The barlow lens for your telescope will double the power of the eyepiece used.
However, despite what the manufacturer claims for your telescope things will look quite poorly if you try to view at 180 power. Generally you'll get the best images by using 50x for each inch of your objective lens. For example, your telescope has a 50mm lens. That's roughly 2 inches. 2 inches times 50x gives you a maximum useful power of 100x. Depending on the viewing conditions you may be able to exceed this or not even reach it. Things will look blurry and dim when you try to use too much power.
Your power or magnification is calculated by dividing your telescope focal length which is 360 mm by the eyepiece focal length. You have two eyepieces with focal lengths of 4mm and 20mm. If we divide 360mm by 20mm we get 18 power. If you add a barlow to that you get 36 power. Dividing 360mm by 4mm (no barlow) we get 90 power. That would be your maximum useful power.
Therefore, you should be able to used the 20mm eyepiece with or without the barlow but the 4mm should only be used without the barlow.
I hope all of the math wasn't confusing.
Feb 12, 2009 | Edu-Science (10166) Telescope
Bushnell 700x76
Jan 29, 2008 | Bushnell 3" Reflector Telescope w/Talking...
What lens do i insert into scope to view the moon
The moon is big so use the 25mm. The Barlow will have a multiplication marking on it 2x 3x etc. A 2x Barlow lens will effectively double the power of the eyepiece you are using. Do not use the erecting eyepiece for anything other than land viewing. Erecting eyepieces generally reduce the amount of light reaching your eye and thus reduce brightness of the faint objects in the sky.
So basically just place the 25 mm lens in the focuser and point the scope at the moon and you will be amazed at what you can see and how bright it is.
Dec 30, 2007 | Tasco 350x50mm Refractor Novice Telescopes
Start by adjusting the focus draw tube all the way in, then back a little bit. In the day time indoors, remove the lens from the draw tube. Look into to the draw tube. You should be able to see your eye centered in the mirror. If you cannot see your eye at all, either the primary is tipped drastically or the secondary mirror is way out of adjustment. In that event I would return this scope to where you got it.
Oct 26, 2007 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Bushnell NorthStar 78-8831 (525 x 76mm) Telescope Logo
510 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
