Make sure that you are installing a fresh/ full charged battery AA non-rechargeable lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). Remove the memory card and the battery Clean the metal contacts on the battery using a clean cloth Use the camera w/o the memory card
Pls test with an alt. batt. If you do not have access to a dif. battery. Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
If problem still persist call the Tech Number
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Was this helpful?
Yes
No
Popular Solutions for Kodak EasyShare CX7530 Digital
lens does not move when you want to take a snap, in fact it got stuck, all other functions are...
(More)
lens does not move when you want to take a snap, in fact it got stuck, all other functions are blocked by the word that comes on when you turn it on; the word reads like camera error N0. 45
Recently the quality of my photos has declined. Some photos are still great, then others are very...
(More)
Recently the quality of my photos has declined. Some photos are still great, then others are very dark as though the flash is not working properly. I have adjusted the flash to every setting and it doesn't seem to help any.
Can I use a 4gig card in this camera? How do I format the card? Kodak CX7530 Easy Share 5.0 Mega...
(More)
Can I use a 4gig card in this camera? How do I format the card? Kodak CX7530 Easy Share 5.0 Mega pixels
