Question about Haier HTQ18JAA Top Freezer Refrigerator
Haier htq18jaa fan replace
How do I replace the fan on my haier htq18jaa. The freezer fan is not running.
    Scholar:
  • 146 Answers
First make sure your door switch is okay. Other problems could be your defrost timer, evap. thermo. etc.. Make sure that it is your fan before replacing it. To replace it you take everything out of the freezer and remove the rear panel. You should see the fan at that point. You can check for voltage at the fan by disconnecting it and measuring for 125V at the leads. If when the door is closed you have power replace the fan. If not check all other possibilities.
Posted on Dec 26, 2007
Drip pan constantly filling up on haier fridge and not cool inside
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 20, 2010 | Haier HTQ18JAA Top Freezer Refrigerator
There is water leaking from inside of the refrigerator from what looks like the sensor that is at the top (ceiling) of the refrigerator. Not sure if it is coming from the freezer into the refrigerator. ...
your freezer cabinet need to get all out also the ice machine(if you got one),and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards.
Jan 05, 2010 | Haier HTQ18JAA Top Freezer Refrigerator
I have a Haier model HTE14WAAWW refrig. with top freezer. The refridge humes loudly. The freezer works, but to lower unit does not get very cold. The fan at the bottom, for the compressor does work. Please...
check the fan in freezer sounds like it is stuck [iced up ] or needs to b lubed at the back of freezer will see fan feel if fan is blowing or just humming
Sep 24, 2009 | Haier Refrigerators
My freezer fan is not working. Can it be fixed?
The fan won't work when the unit is in the defrost cycle. Some won't run when the door is open. It won't run when the compressor isn't running. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php And yes, you can replace it.
Jul 11, 2009 | Haier (492420265334) Refrigerator With Ice...
Not keeping things cold
check to see if the compressor is running in a cycle. if the compressor is not cycling, you will need to replace the compressor and fan.
if the compressor is humming, it because of a faulty motor and relay(start device). replace the compressor unit in this case.
May 22, 2009 | Haier HRF10WNB Top Freezer Refrigerator
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Apr 04, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
Freezer cold, fridge warm
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Mar 17, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Cold freezer-motor burned up
I had the same issue, but without the burnt parts.
Sep 22, 2008 | Haier HTQ21JABWW Top Freezer Refrigerator
Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
Apr 02, 2008 | Haier HTQ21JAAWW Top Freezer Refrigerator
Refrigerator seems to run all the time
Hey Wisper, I had a very similar problem with my Haier. Read all about it here: http://www.fixya.com/support/t180574-freezer_10_deg_fridge_50 I replaced the thermostat ($35 or so, mail ordered) but that didn't do very much. Then I replaced the Evaporator fan ($40 for an OEM part, read the details on my other page) and that did the trick. Feel free to email me if you want more details of what the job involved. I'm @gmail.com and the address is RobCuthbertson
Apr 12, 2007 | Haier HRF10WNB Top Freezer Refrigerator
Haier HTQ18JAA Top Freezer Refrigerator Logo
179 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
