Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Mits diamond vision 65
My 65 inch diamond vision is getting black vertical lines starting at each lower corner and heading up, screen is not dirty etc, and it is getting worse, started with 2-3 in each corner now they almost touch in the middle, lines are not even, resembles an led VU meter,, thanks jay
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Jan 19, 2008
I have a Samsung 65 inch curved tv. It has a small black horizontal line. Also a large 4 inch black vertical stripe on the left side of the screen. Do you think a new tcom board would fix the problem?
Try unplugging all the connectors between the TV circuit boards and then plug them back in (be gentle they are fragile), this can often be caused by a poor connection.
Oct 25, 2017 | Samsung Televison & Video
Vizio XVT3D650SV 65-Inch Theater 3D Edge Lit Razor LED LCD HDTV has a black vertical 6" wide line on the right side of screen. What is causing this problem? Is it the T-Con board?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 23, 2016 | Vizio Televison & Video
Mitsubishi diamond vision 27" 1995
It is an indication of leaky electrolytic capacitor on the vertical section.
This is not a diy if you are not an expert.
I've adviced you to look for a qualified technician to replaced the faulty capacitor.
This is quite fixable and easy to locate by the technician.
pls rate my help...
Thanks for using fixya.
Jan 14, 2011 | Mitsubishi CS-27205 TV
please let sony know as i have the same probem and they are not acknowledging the problem with this model
Jan 16, 2010 | Sony BRAVIA KDL-40V3000 Television
Vertical lines/black squares all throughout this 50" TV. Is it worth fixing?
I have 5 vertical black bars coming down halfway on the screen. Also 1 black square that appears on the lower half corner of the screen. What can I do to get them off? Please respond or call me @(510)938-6237 Shon Thanx!!!
Dec 27, 2009 | Mitsubishi PD-5010 50 in. Plasma...
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a 56 inch JVC HD TV model# HD-56G647. yesterday when I turned the set on there was a black shadow in the lower hand corner. today it's bigger. i called jvc and they told me to make sure the...
Red light lamp indicator is blicking on my 56 inch mode;# 56G647 tv and the Tv screen is black with no vision of tv and no sound. What sould I do
Oct 17, 2008 | JVC Televison & Video
Vision 42 inches plasma tv
It sounds like there is a problem with the tuner inside the television. Your best bet is to send it in for service.
Jan 30, 2008 | Vision HDV-42P2 Television
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
122 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
