Sony FD Trinitron WEGA KV-32HS420 32" TV
Problem for Sony FD Trinitron WEGA KV-32HS420 32" TV
Have a sony tv model
By rbznfrlo on Oct 12, 2009
have a sony tv model kv32hs420 mfg 11/04 two problems. 1) recently tv was freezing its picture and short bursts of picture squares were shown then correct picture was showned 2) the tv no longer stays on what happens is it clicks on then off in the front of the tv next to the power button there is a red blinking light above the light are the words stand by/timer attempeded correction unplugged tv and cable box and attemped to reset no improvment Called local cable company for help went through process and cable company responded that it was the tv and not cablebox Question is there a reset button on tv or tv remote can this an internal problem
Best Solution
posted on Oct 12, 2009
Very Helpful)
johnnydiode
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 94%, 204 votes
This is an internal problem there are no resets.To be shure the remote is not sending a signal that turns the set off temporarily remove the batteries.
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour. Be sure to vote/rate me if this helped Thanks!
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for Sony FD Trinitron WEGA
Questions and Unsolved Problems for Sony FD Trinitron WEGA
Do you recommend Sony FD Trinitron WEGA KV-32HS420 32" TV?
Answer
Answer
My Tv will not turn on and the standby light blinks 7 times then a pause and repeats 7 blinks again.... (More)
Answer
My Sony Wega TV will not turn on. The stand by red light blinks 6 times then stops and starts again.... (More)
Answer
tv will not start after setting over night on the first try or two. once on will come on and run.... (More)
Answer
our sony tv model # kv-32hs420 has a standby/timer button that keeps on flashing red and it's not... (More)
Answer
MY Sony KV-32HS420 stand by timer blinks 7 times then pauses, and the TV won't come on for several... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony FD Trinitron WEGA...:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
