Question about Fisher and Paykel GWL11 Top Load Washer
Machine stops during run time & lights keep flashing and beeping
The washer has been stopping during or after the wash cycle. It then begins to beep about 1 time per second. The 3rd and 4th light in the wash cycle and the first light in the rinse cycle are lit. The manual says I should unplug machine for 60 seconds and then start again. If I do this it runs through completely fine, but then the next time does the same thing. I have also just powered off and advanced it to the rinse cycle it works fine at that point as well.
  • itfigures Jan 02, 2008
    I am having the exactly the same issue. Out of warranty by 2 months....
  • yukijkd Jun 28, 2008
    The washing machine spins until the 'gentle' process, but stops working when it reaches the 'rinse' process and makes a motor-like noise. What's the problem? What can I do?
  • 28 Answers
(00110100) code 53 Diverter Top-up Faultafter 6 attempts to top up with water machine has failed. Possible causes are
1 water flow to slow
2 diverter vavle stuck in half open position and water pumping out as quickly as it comes in
3stuck in pump out and lowering water level totally
See if water is flowing out drain hose when washing ,if drain hose is to low water can siphon out and show same fault code
Posted on Jun 21, 2008
The Water Hose on The Hot water side has an automatic flood insert inside the hose so if the hose breaks it will shut off the supply of water to the machine. Changed hose and the machine runs perfectly.
Thanks for your timee
Ed
Posted on Mar 06, 2008
    Sergeant:
  • 351 Answers
It may be a balance problem
Posted on Mar 03, 2008
5 Suggested Answers
SOURCE: Fisher and Paykal GWL 10 US - Stops before rinse
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Posted on Aug 20, 2007
  • 58 Answers
SOURCE: 1 beep per second and odd light sequence
stuffing from the pillow could have plugged ip the pump or diverter valve located on the bottom of the machine
Posted on Oct 31, 2007
  • 1294 Answers
SOURCE: The washer has been stopping during or after the wash cycle. It then begins to beep about 1 time per second. The 3rd and 4th light in the wash cycle and the first light in the rinse cycle are lit. The
Plug off the wall. Open up behind the machine. Check to see if any wires loose. See that the wires from the control panel to the motor are plugged in tight. Vibration from the machine could loosen the wires and give the display wrong readings, or disrupt the run.
Rate me please..........
Posted on Dec 26, 2007
SOURCE: beeping and odd light sequence
I have the same problem with my 603 washing machine stopping in the middle of a cycle and i would have to go and manually advance the wash. I have just replaced the top curcuit board with a new one. can you please help or offer a solution. Thank you.
Posted on Oct 05, 2008
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
I have a Whirlpool washer WFW9050XW00 that stops during the wash cycle. The machine beeps and the wash light flashes 9 times pauses and flashes 1 more time. Thanks in advance
My Washer stopped while washing and will not spin drain or aggitate.
It will power on and off I can change the settings but nothing happens.
Oct 26, 2013 | Washing Machines
Washing mchine stops during cycle and starts beeping
See if you are overfilling you machine or the load is out of balance. Even try running the machine empty
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washer won't stop beeping and can not change cycle selections
what light is flashing when it beeps. You might have to check and see if you are getting water to both Hot and Cold on the machine. Or your door might be closed all the way
Jul 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Beeping and odd light sequence
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
521 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
