Ricoh Aficio 1013F Copier
Problem for Ricoh Aficio 1013F Copier
Aficio 1013f scan
By zkostic_sdlg on Oct 12, 2009
aficio 1013f scan?
How to scan documents and than save it on my pc or send them via mail?
I need help because my aficio have italian titles on it.
Comments:
Oct 13, 2009
- i have print and fax option for sure, printer is atached to network and three pc -s are printing on him but there is problem with scan, i think if i can print trough network i can and scan but how?And yes i think it will be helpful to have it on english. thanks
Oct 13, 2009
- what is nic option?
Oct 13, 2009
Oct 13, 2009
- ok i think i get it i need to scan it like a fax but how then to see it on my pc? where is that memory?
Clarification Request
Posted by auburnconsul on Oct 12, 2009
do you have the scan option? do you have the nic optiokn? do you have the print option?do you need it in english?
Solution #1
posted on Oct 17, 2009
Not Rated)
socalern
Rank: Master
Rating: 88%, 3 votes
This is a loaded question. the 1013 can be either a network scanner (nic) or a twain scanner. this will depend on the type of hardware interface that is on your machine. Network scanning is the preferred method. I noticed that your model is a1013f which leads me to believe that it may not be equipped with the scan hardware. You need to look at your control panel and verify the scan button is there
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 1013F Copier
Questions and Unsolved Problems for Ricoh Aficio 1013F Copier
Do you recommend Ricoh Aficio 1013F Copier?
Answer
Answer
hi i have a copier/printer Ricoh aficio 2105 . the problem is that i safely turn off the copier but... (More)
Answer
in which part should be serviced if a canon NP6035 copier machine frequently get paper jammed
Answer
I used NP 6035 Canon copier for small fotostat business. It's recond machine. after 3 years some... (More)
Answer
paper frequently jam what is the cause
Answer
please what does the following codes means on konical 1212
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio 1013F Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 766
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
