Question about Panasonic DVD-A310 DVD Player
Huge black box in center of screen
I have had this dvd-a310 player for a long time and it has worked fine but yesterday i put in a dvd and this huge black box appeared in the lower center of the screen. also dvds skip around when playing. the black box does not disappear even when there is no dvd in the player. any suggestions?
techman
  • 3130 Answers
SOURCE: Faut F489
This is for code f489 as well as f498 F498 means a problem with flash eprom IC; meaning that unit is unable to read the basic instructions from the eprom IC. Can be cuased by several; may simply be a "bad connection issue" at the eprom Ic or somwhere in the Bus line--defective Ic or corrupted information which may or may not be recovered with a "service recovery" disc.(not an end user procedure) First step; try resoldering Eprom ic being careful not to bridge pins. second would be to take the unit to a AUTHORIZED ONLY repair shop for a firmware or eeprom update. Good Luck
Posted on May 24, 2006
tvtek
  • 1284 Answers
SOURCE: black box appears on screen when using dvd player
On the TV menu check to see if the TEXT mode is activated if so deactivate it to clear the issue. This will be in the Closed Caption settings menu.
Posted on Mar 09, 2007
  • 286 Answers
SOURCE: Two problems at the same time: VCR plays split screen and DVD player won't ready Disks (Errrrr)
Getting a new one is about all you can do in this case. A repair for this type of problem would likely cost more than the replacement.
Posted on Nov 04, 2008
  • 218 Answers
SOURCE: Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Posted on Mar 07, 2009
Beignorant
  • 51 Answers
SOURCE: All my dvds are suddenly playing in Black & White only
Double check your RCA cables, it might be switched around. hope I was able to help a bit
Posted on Mar 30, 2009
Black box won't go away during DVD play
is it just during dvd's or does it happen at other times
Sep 25, 2008 | Sony KP-53S35 53" Rear Projection...
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Sylvania tv not recognizing DVD player
Do one thing press the SCREEN MODE button on the remote repeatedly and check is there is any difference in the screen. If there is no difference then yu tv Have problem wit the T Con board, T con board is on which drives pixels the lcd screen. You can find the T con board of your tv in the following link.
Normally you can find the T con board inside the tv at the bottom center covered by metal cover or aluminum foil. Replacing this board will solve the problem.
http://www.ebay.com/itm/BUF320G04012-T-CON-SYLVANIA-LC320SS8-/140556173476
If you need any more assistance feel free to contact me through fixya
Ajin
Nov 23, 2011 | Sylvania LC320SS8 32 in. LCD Television
Up until yesterday our dvd player was fine, today I put in a dvd and there is no sound. I have put a couple of dvds in and there is no sound except for one dvd I put in this works fine?
the dvds you put in are not compatible to your dvd player.but you can clean the lens and see what it does.good luck.dvds work with region.check the region of your dvd player and dvd you are attempting to play.
Mar 04, 2011 | Televison & Video
Akai portable dvd player - broken screen
ur player lcd is damaged or loosened take it to roduct service center and they will do it ok
Mar 30, 2010 | Televison & Video
Black box appears when I hook up xbox or dvd player?
Try turning off any closed captioning if it is on.
Sep 21, 2009 | JVC Televison & Video
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Panasonic DVD-A310 DVD Player Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
