Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Whirlpool Refridgerator Noise
I have a 2004 Whirlpool Refridg where recently the thing makes this relay/ electrical-type groaning noise (60Hz) for 15 seconds then knocks loudly. Im wondering if this is a stuck fan or something. The fan inside the unit works, but thats all i can hear for noise otherwise. Any ideas???
  • brauem Dec 27, 2007
    Wanted to add some more information...
    The noise seems to be a loud 60hz buzz as something is switched where you get a buzz for about 5 seconds then after it stops, a clunk/ knock after about 5-10 seconds. The refridge seems to be cooling effectively as i measured tempertures of both compartments. I did feel air flow moving in and out of the under door/ bottom louvers. Does this sound like the relay ? or compressor?
    any help you can provide would be helpful...
    Scholar:
  • 146 Answers
Check your condenser fan motor. It is located under the refer and it cools the compressor. It doesn't blow at the compressor but sucks the hot air away from the compressor and usually out the front of the refer. I have seen occasions where a mouse has gotten into the fan and caused a rapping sound. Also check for fallen insulation under there. Sometimes the compressor will make the same sound you are hearing. Your best bet is to unplug the refer for about 10 minutes while unplugged open the doors so your thermos will close then while in back of the refer plug it in and you may be able to determine where the sound is coming from. That will tell you whether it's under there or inside the refer.
Posted on Dec 26, 2007
    Sergeant:
  • 288 Answers
Why did you put the megahertz (60 hz) on your question? Get access to the back of the fridge, take the panel off, on the bottom, there is a compressor and condenser fan motor. Look these two and see if the noise can be found here. The fan should run when the compressor runs. If the fan is running and quiet, put your hand on the compressor. It should be warm, slightly hot, but not so that you cant leave your hand on it. If it feels hot and the fan is running, clean off the coil underneath the fridge. Often this is the only problem as nobody hardly ever cleans this thing off. Its the equivalent to the radiator on your car.
Making noise when spinning
bearing going bad, ride it until you cant stand the noise then get another machine, not worth changing the bearing
Jan 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi. I own a 2004 Buick Rendezvous and I must say, it's the best car I've ever owned. Recently, like within the last 2 months I've had a groaning noise with every left turn. My husband filled...
he filled the PS fluid? it was low? If so it has a leak somewhere, usually the high pressure line. the rattle could be anything, have the front end and steering linkage checked. tie rods, sway bar links, ect.
Aug 03, 2011 | 2004 Buick Rendezvous
The freezer is working but the refridgerator is not... noise when open the refridg. door, but light is off and no cooling.
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<br /><br />Refrigerator not Cooling or Fridge not Cooling<br /><a href="http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not" target="_blank">http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not</a><br /><br />How to Defrost Refrigerator Defrost Timer Problem <br /><a href="http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer" target="_blank">http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer</a><br /><br /><br />Water Running in efrigerator from Freezer<br /><a href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target="_blank">http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</a><br /><br />heatman101</span><br />
Aug 26, 2010 | Whirlpool Refrigerators
Whirlpool side/side. 3yrs old from Lowes. Something electrical tries to come on about every 30 seconds - 1 min. Hums for about 10 - 15 seconds and then stops. Freezer started not keeping everything frozen...
There is a relay overload on the compressor that makes a noise similar to what you are describing when the compressor does not start. Sometimes the electrical parts can be replaced, the rest the compressor is bad and needs replacement.
The other less likely possibility is that the ice maker is not hooked up, the arm got put down and the ice maker is cycling causing its heating element to run and the noise from the water valve.
If you pull off the back panel behind unit you should get some idea where noise is coming from
Jan 10, 2010 | Whirlpool ED2FHSS Side by Side...
Not freezing and making a noise every 20 seconds
It is one of the common problem that occurs in the refridgerator.
It can be due to the faulty start relay or the compressor.
Jan 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
My Whirlpool refrigerator makes a loud groaning cough noise when it turns off. Is it near the end?
the compressor is pushing a lot of pressure. when it shuts off sometimes the pressure forces the compressor to roll backwards and make a pressure release noise. I've known some to do that for years.
Jun 08, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpoor Refridgerator 10-12 yrs old
I had a whirlpool fridge that did the exact same thing. Sometimes it was loud enough to wake me up at night! It is the compressor shutting down. I had it for several years untill I purchased a larger one, and then gave it to a girlfriend at least a year ago. Its still working good today. So if you can tollerate it, just live with it. Otherwise change the compressor.
Jan 04, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
216 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
