Question about Sennheiser RS 110 Consumer Headphones
  • Anonymous Feb 18, 2008
    i have a home theater connected to my tv which is connect to my cable box.
  • steveb28 Dec 27, 2008
    I can't seem to tune headset to television
Make sure you are connecting to the OUTPUT section and not the input, look in the back of the television it should say output and have its own red and white pluga, if you connect the red and white cables to the input section on the front of the television or on the section on the back that says input you will not get any reception make sure you are connecting to the output
Posted on Dec 31, 2007
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
How do I eliminate static?
A lot of times when head phones of a head set have static it could mean that dust and/or water have gotten into the ear piece and the sound wave rattle around the gunk. that's about all i know.
Jul 08, 2012 | Televison & Video
How to open up to chick the hard drive
Before you start, be aware that minute traces of static electricity can destroy a hard drive. If possible, wear an anti-static wrist or foot strap; at the very least, do not work on a carpeted floor, bed, or while wearing static-producing clothing (like fleece). Work on a non-conductive (wood, glass) table grounded to a non-conductive floor (wood, linoleum, tile). Wear latex or anti-static gloves and turn off fans and close windows to avoid dust damage.
1. If you haven't already, back up your data on an external drive. 2. Shut down the computer and unplug the power cord from the computer. Remove the battery. 3. Close the laptop and set it screen-side down on an even surface, with the hinges facing away from you. It should look like this:
4. The component labeled "7" in the above picture is your hard drive. With a small Phillips head screwdriver, carefully remove the screws on this outer casing only. Set them aside and remove the hard drive cover. 5. Your hard drive will be screwed in by one to four screws, depending on assembly. Gently unscrew these, being careful not to apply too much pressure to the very delicate top and bottom of the drive. Handle by the sides only. 6.There are connecting pins on one side of the hard drive. Identify these and gently pull the hard drive out from this side, not forcing if there's any resistance. 7. Depending on your problem, you may need to remove the silver enclosure to the hard drive. With the appropriate Phillips head screwdriver, unscrew the screws and set them aside, carefully sliding the enclosure off of the hard drive. At this point, your hard drive is extremely susceptible to shock, electric shock, dust, and simple trauma. Be careful.
May 18, 2011 | HP Compaq Presario V5210US Notebook
How do I replace the front left (driver side) headlight? I have removed the cap and the electrical, but can't figure out how to remove the bulb so I can put a new one in. Your help is appreciated.
Removal & Installation
  1. Disconnect the negative battery terminal.
  2. Remove the head lamp mounting bolts, then disconnect the lamp connectors.
  3. Replace the head lamp bulb(A), position bulb(B) and turn signal bulbs(C).
    Head lamp bulb(A), position bulb(B) and turn signal bulbs(C)
  4. To install, reverse removal procedure.
Dec 12, 2010 | 2005 Hyundai Tucson
How to replace head light
The headlight replacement procedure.:---
  • Apply the parking brake and open the hood.The head is attached by thumb shaped screw.You will see the thumb screw on the upper inboard corner of the turn signal assembly Remove the screw with the screwdriver.Pull the turn signal assembly outward away from the fender and then disconnect the bulb.Turning the socket and wire 1/4- counterclockwise. Set the turn signal assembly aside.Disconnect the electrical connector plug from the headlight being replaced. Lift up on the blue retaining clip of the plug and pull it away from the socket of the headlight.Turn the black retaining collar of the headlight counterclockwise to remove it and the headlight from the headlight assembly.Install the new headlight by reversing the procedure.Replace the turn signal bulb into its assembly and reinstall the assembly and thumbscrew.
  • Nov 12, 2010 | 2005 Pontiac Montana SV6
    Cannot figure out how to get the light assemble out to change the turn signal bulb on my 2000 chevy blazer
    thats simple open your hood theres 2 plastic tabs right behind the head light assembly they have 2 slides on them that lock over some bolt head looking post, pull up on them then the whole head light assembly pulls out easy fix
    Mar 13, 2010 | 2000 Chevrolet Blazer
    Cant figure how to get to bulb
    There are 2 pins and 2 bolts that hold in the head lamp. Remove the head lamp to access the signal bulb. Good Luck
    May 31, 2009 | 2007 Chevrolet Uplander LS Minivan
    My H700 Motorola Bluetooth Headset
    i just want to know how to get it to work in the first place... got a new phone and need to set it up but i lost my directions. how do i just get it to work
    Oct 01, 2008 | Motorola Mobility H700 Wireless Headset
    Cant figure out my car audio problems!!!!!
    There are a couple of tests you can perform. I'd first recommend checking the shield ground. You'll need an ohm meter. The details can be found on the following page.
    RCA shield ground test
    You can also test the output with the multimeter. Set the multimeter to AC volts. If it's not an auto-ranging meter, set it to a voltage range of ~2v AC. Disconnect the RCA cables from the head unit. Touch one meter probe to the outer ring of the head unit's RCA jack. Touch the other probe to the metal contact in the center of the RCA jack. With the head unit near full volume and a clean signal source, you should read at least one volt on musical peaks. If you have a bass disc or a test tone disc (~60hz sine wave), use those.
    May 04, 2008 | MTX Thunder 8302 Car Audio Amplifier
    Hard drive removal
    1. Loosen the two Phillips-head screws that secure the hard drive cover to the bottom of the notebook.
    2. Use your finger or a flat-bladed tool to lift the inside edge of the hard drive cover and remove it.
    3. Loosen the spring-loaded Phillips-head screw that secures the hard drive.
    4. Hold the Mylar tab and pull the hard drive toward the outside edge of the base enclosure to disconnect the hard drive from the system board connector.
    5. Lift the hard drive out of the bay and remove.
    6. Place the hard drive in a static dissipative bag.
    Replace the hard drive
    1. Remove the hard drive from the static dissipative bag.
    2. Place the hard drive into the hard drive bay.
    3. Push the hard drive toward the inside of the base enclosure until the connector is seated.
    4. Tighten the spring-loaded Phillips-head screw that secures the hard drive.
    5. Insert the hard drive cover into the enclosure.
    6. Tighten the two Phillips-head screws.
    Nov 16, 2007 | HP Pavilion Ze4805us Notebook
    Sennheiser RS 110 Consumer Headphones Logo
    478 people viewed this question
    Top Sennheiser Audio Players & Recorders Experts
    Michial Gueffroy
    Vito Vacirca Jr.
    Rob Beech
    Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
