Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Blurry pictures Our display screen went out and we got it repaired now the camera is takes blurry pictures and cannot get it resolved any suggestions
  • 790 Answers
How to Fix It 1.
Don't overlook the obvious. Start by cleaning your lens, and cleaning it properly. You can get a good quality lens cleaning cloth or paper at virtually any camera shop—which is a good idea to keep handy even if you your current problem isn't a dirty lens.
If cleaning the lens solves the problem, there's no need to go through the rest of the steps here, but there are things you should do to help protect the lens from getting dirty in the first place, namely: Always keep the lens cap on the camera when you're not using it, and be careful not to touch the lens with your fingers.
If cleaning the lens doesn't solve the problem, consider whether you are holding the camera steady enough while you take the picture. Some cameras are harder to hold steady than others, because of their shape and the placement of the shutter button. You can test whether this is the problem by taking a few pictures with the camera sitting on a rock-solid surface, like a table top.
If the pictures you take when the camera is firmly supported are suitably sharp, you need to practice a bit with taking pictures to learn how to hold the camera steady. When you take a picture, breath evenly and slowly—or even hold your breath for a moment—then gently squeeze the shutter button, rather than hitting it sharply. This is particularly important for cameras that are relatively long from back to front and have the shutter button near the front (the lens side). There's a strong tendency with this camera design to pivot the camera as you press the button.
Also, if your camera offers automatic focus, automatic exposure, or both, make sure you know how to use it. Typically, you'll need to press the shutter button halfway and hold it a moment to give the auto modes a chance to lock on before you actually take the picture.
Finally, keep in mind that there may be a lag between the time you press the shutter button and the time the camera takes the picture. If you start moving before the camera is finished, the image is all but guaranteed to be blurry.
If you still can't hold the camera steady enough for a sharp picture in all situations—which may be more of an issue with zoomed pictures—consider getting a tripod or monopod to help steady the camera.
If the lens is clean, the camera is steady, and the images are still blurry, you may be taking the pictures with too low a resolution or too high a compression setting (or both) for the final images you want to produce. It's easy enough to test for this by taking some pictures at the highest resolution with no compression and seeing if that solves the problem.
Find out how to set resolution and compression. Some cameras let you set the two separately. Others have a choice of quality settings that combine various levels of resolution and compression. The difference between using the lowest resolution with highest compression compared with using the highest resolution with lowest compression can often make the difference between fitting over 100 pictures on your camera's storage and fitting just one or two pictures.
Take a few photos with the highest resolution and lowest compression available for your camera, and see if the resulting pictures are suitably sharp. If they are, try one step lower on the quality scale, and check the results again. Keep going until you find the quality level for the camera that begins to degrade the sharpness of the pictures that you wind up with, and use one quality step higher. Note that the best quality setting to use will vary depending on how you plan to use the picture. For example, photos meant for viewing on a Web site shouldn't need anywhere near as high a resolution or as low a compression setting as photos you want to print at 8 x 10 inches.
Posted on Dec 26, 2007
  • Kanth raj
    Kanth raj Dec 26, 2007
    and also try hard resetting of the camera once coz u had given for the service right ...
  • 70 Answers
Had the cam fallen down? It could be because the lens has dislocated from its location. (Presuming that you did not have this issue of blurry pictures before.) I would suggest you see if the lens is intact. If yes, try and put the camera on AUTO mode and shoot some portraits. If it still does not work, try manually setting a high shutter speed and see if u still get blurry pictures..
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Blurry Display Screen and 2 beeps with shutting Off
check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
Jul 13, 2009 | Samsung S860 Digital Camera
Sony DSC-T1 Camera - Blurry display and picture
Its bad ccd imager problem in DSC-T1 and ccd imager will be replaced.
Sony will repair your camera free of cost for same problem as per announced scheme.Only $20 for shipping charges.
Click Sony CCD Support for details.
Apr 08, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Blurry camera screen
If the pictures are blurry, you probably damaged the lens with the drop. You will have to send the camera to the factory service to replace the lens unit, if it is not serviceable.
If you drop a camera this is not normally covered by the warranty. You may find it cheaper to replace the camera than have any major service done to it.
Jerry G.
Apr 27, 2008 | Cameras
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Blurry screen on dig. camera
Same problem here any razon or fix yet?
Feb 25, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
I have a Casio EX 260, not the EX-S600
Try resetting camera. If that doesn't work more than likely there is a lens error. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 07, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blurry Vision
What are you looking at on the screen? Before or after the shot? The this point the taking sequence-point camera at scene look in screen blurry image - half press the release - autofocus comes into play- press all the way picture takes.Sharp picture in the taken images what are you doing?
Sep 08, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Blurry Camera
I have a kodak c300 digital camera Whenever i take a picure it is blurry on the display and it comes out blurry off the chip
Jun 16, 2007 | Kodak EasyShare C300 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
