Question about Fisher and Paykel GWL11 Top Load Washer
The washer has been stopping during or after the wash cycle. It then begins to beep about 1 time per second. The 3rd and 4th light in the wash cycle and the first light in the rinse cycle are lit. The manual says I should unplug machine for 60 seconds and then start again. If I do this it runs through completely fine, but then the next time does the same thing. I have also just powered off and advanced it to the rinse cycle it works fine at that point as well.
    President:
  • 1,294 Answers
Plug off the wall. Open up behind the machine. Check to see if any wires loose. See that the wires from the control panel to the motor are plugged in tight. Vibration from the machine could loosen the wires and give the display wrong readings, or disrupt the run.
Rate me please..........
Posted on Dec 26, 2007
  • prem mathew Dec 29, 2007
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
Keeps stopping during wash cycle
Hi Kathy,just read your posting.When the machine stops during the cycle does the machine beep and show an error code?Could you confirm the model number of your machine.Now if you have an LCD screen on your machine the fault code will appear in it but if you have no screen then the error code will appear as lights .These lights will be a row of 8 lights.Starting from the left to right which lights are on when the machine is beeping.Is it the 2nd and 4th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
We have a WGL 10 US model F&P washer. Most
Are you waiting long enough? Ours seemed to stall but eventually would start up again. Have you tried diagnostic mode? email me at Yahoo.
Sep 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Beeping and odd light sequence
I have the same problem with my 603 washing machine stopping in the middle of a cycle and i would have to go and manually advance the wash. I have just replaced the top curcuit board with a new one. can you please help or offer a solution. Thank you.
Fisher and Paykel GWL11 Top Load Washer Logo
175 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
