Question about Sony Playstation 3 (PS3) Console
Hard disk currupt
Hard disk is currupt and will not reset
as many times that it tells us to do it will not fix itself
need a new hard drive??
was played on for 4 hours but this is what has happened
  • howes Dec 26, 2007
    my playstation 3 does not read any discs after i played assains creed please help ive tried restoring factory settings still not working
  • fabe Dec 26, 2007
    my ps3 when turned on says the hard disc file system is corrupted and will be restored. so i press ok and it continues to come back to this message. please help me
    Problem Solver:
  • 6 Answers
My sonin law got one of these ..and told me never pick up this ps3 while switched on ...makes sence as hdd drives unless supporting anti-vibration can jump a sector on a disk and thus currept your hard drive ...try this web page i've found it might help or inspire to upgrade your small 40 /60 gig hdd
other wise buy a good speck pc
Posted on Dec 26, 2007
    Problem Solver:
  • 10 Answers
Unfortunately it sounds like you do need a new HDD.
If you only played for 4hrs I can only assume that your machine is still under warrenty- in which case SONY should fix the problem for you.
If not, follow this link for a good step-by-step guide to replacing it, seem fairly straight forward -
Make sure you read the NOTICES section at the top of the page so you know what you are getting yourself into.
Also, check this link to actually see someone doing it before you attempt it yourself -
!!!!!!!!!!!!!!!!!!!!!!!!!!!REMEMBER OPENING YOUR PS3 YOUSELF WILL VOID YOUR WARRENTY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
How do I fix currupt data
I believe you mean "corrupt data". When we have message corrupt data means that something wrongs with hard disk. You can try correct problem running full disk check.
Check your hard disk for errors
You can help solve some computer problems and improve the performance of your computer by verifying that your hard disk has no errors .
Open Computer by clicking the button " Start " and then click Computer.
Right-click the hard drive you want to check, and then click Properties.
Click the Tools tab , and then , under Error-checking , click Check . Administrator permission required If you are prompted for an administrator password or confirmation , type the password or provide confirmation .
To automatically fix problems with files and folders that the scan detects , select Automatically fix file system errors . Otherwise , the disk check will report problems but not solve .
To run a full disk check , select Scan for and attempt recovery of bad sectors . This scan attempts to find and repair physical errors on the same hard disk and may need more time to complete .
To check for errors in both files and for physical errors , select both check boxes AutoCorrect file system errors and Scan for and attempt recovery of bad sectors .
Click the Start button .
Depending on the size of your hard disk , this process may take several minutes . For best results, do not use your computer for other tasks while it lasts error checking .
If you select the Automatically fix file system errors for a disk that currently in use (for example , the partition that contains Windows), you will be prompted to reschedule the disk check for the next time you restart your computer your .
Jan 29, 2014 | Toshiba Computers & Internet
Each time i turn it on it reads.The hard disc file is currupted and will be restored it then tries to restore itself but then starts all over again
Hello this is a common problem with the sony Playstation 3.
Here is a simple solution to your problem. Go to settings, format hard disk. Then go to system settings, and choose the option full format. this will take a approximately 3-4 hours to complete. Any further questions please feel free to ask. Thanks for using fix ya.
Dec 07, 2010 | Sony Playstation 3 (PS3) Console
After formatting my currupted external 640GB HDD (Transcend Storejet 25M),I can only save 10 or so GB of data/video before it gets unresponsive.At this stage,the computer itself (Vista) does not response....
The data on the external disk was corrupted because the hard disk from it was dying. Take it out of the case , put it directly in a desktop and test it with HDTune (the free version of course) -it will tell you the damage status and if it's recoverable.
If not then it's dead - junk it.
Aug 29, 2010 | Computers & Internet
Acer Netbook OS
if you are getting this message about corrupted partitions, you need to check and possibly replace the hard drive. There is a program to check the hard drive called Hard Disk Sentinel. It is designed for SSD hard drives like the Acer Aspire One has. Yours has a 160GB hard drive in it now.
Mar 26, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do i do a master reset on my laptop and fix a currupt C drive
Run system restore disk or run it from the bios or the hard drive.
Apr 22, 2009 | Computers & Internet
San disk micro 16 GB usb not working
Mar 21, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Hard disk problem(locked by a password)
Hi Someone has set the hard disk password in the BIOS. This stops the hard disk from being accessed until the password is sent to it. The hard disk itself is now locked - you cannot put it in another system - it will just not work until it receives the correct password. I am sorry but unless you know the password there is no way to access the data on the hard disk. You would have to send it to a data recovery firm or possibly return it to the disk manufacturer but contact them first as they will probably destroy all the data on the hard disk. Sorry - but you will have to buy  new hard disk and reset the CMOS before you fit the new one and remove all BIOS passwords.
Jan 26, 2009 | Toshiba Tecra S2 Notebook
My ps3 tells me the hard disk is corrupted
Sounds like you might need a new hard drive. You could try to disconnect it and reconnecting it, but usually it does not fix the problem. just remember you need a 2.5 sata hard drive (might be a good thing, if you ever wanted more hard drive space).
Dec 13, 2008 | Sony Playstation 3 (PS3) Console
Dell inspiron e1505 not booting up(currupt hard drive). Did system test and getting serveral errors for hard drive test fail. error ofoo:1a44,065d,0244, Thanks, Rob
You have two options, try to back up your data and reinstall windows is that hard disk or buy a new disk, install it windows and use the old disk as second HD, just to store data.
Aug 13, 2008 | Computers & Internet
Could u tell how to recovery my hard disk
Hey , data recovery is not difficult for normal data loss problem, but if the hard drive is damaged, then the first thing you need to pay attention to is fixing the hard drive.
But you need to notice that after fixing the hard drive, all the files are gone and it seems like it is a new hard drive. At this moment, don't put any new files into the drive 'cause if this happens, you will meet data overwritten situation and if this happens, the chance of data recovery will be reduced.
You can check more details in this post:
Mac Hard Drive File Recovery Recover Files from Formatted Mac Hard Drive
Nov 28, 2007 | LaCie Bigger Disk (300874) 1 GB Hard Drive
Sony Playstation 3 (PS3) Console Logo
85 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
